Blown plug away from home
I've read in these forums a shot of PB Blaster or other pentrating oil around suspect plug threads helps with the older style steel threads. I run a 5.4 gas V-8 and use nothing but the Motorcraft plugs along with a dab of nickel base anti-seize, torque slowly to 20 ft/lbs. With just over 254K miles not blown one yet!
Anyway, here's a pix of the last two that blew out. If I wasn't looking for thread problems they would look normal.
PS. I'm saving my cop's with the broken flanges for emergency repair. They should still work, just need to fabricate a mount, right?
Thanks for your help, Great forum.
The plugs in the pic show a lot of corrosion on the threads due to the exhaust getting through, I believe. With the problems you have had you should get a repair kit from Sears for about $40.00 and carry it with you in the truck along with whatever tools you might need.
I have the kit I mentioned and used it on my Navigator with excellent results.
They look like the SP479 plugs which are the updated plugs that are speced for all the 99'-04' modulars.(Nickel plated) The Autolite equivalent is the AP103 which is exactly the same as the SP479 except the Autolite plug has a black finish. I never had issues with either plug. The extra thread length on the plug do not do anything if the head doesn't have the extra thread length also, obviously.
MC SP479
More Information for MOTORCRAFT SP479
Autolite AP103
More Information for AUTOLITE AP103
MC SP479
Autolite AP103
MC SP479
Autolite AP103
MC SP479
Autolite AP103
They are the SP479 plugs. I now have four inserts installed (2,5,7 &9). This is the scariest job I have ever done in my 50 years playing DIY mechanic, ie. eight hours procrastination--2 hours installation! Hope I don't need to drill any more holes in my heads, but I'll keep a few inserts on hand just in case.
I never would have done this without the help from this great forum. Thanks guys for your support and advice.
turbolaser
1997-2006 Expedition & Navigator
16
04-28-2022 05:42 AM
