'95 460 efi loses power towing slight grade
Old 07-28-2011, 01:42 PM
kitfarley's Avatar
kitfarley
kitfarley is offline
I have a '95 F350 Dually that I have pulled a 28 ft 5th wheel for 10 years. the last time I took it out it would pull fine but start losing speed up slight grades. It will shift down and continue but there is no speeding up. this Truck use to sling this camper around on the freeway. I pulled it from California 10 years ago. The truck misses a little what I thought was water because I could switch to the other tank and it would stop. It is not missing when losing power on the towing. the tranny is shifting a little harder that usual and I am thinking something in there is what is causing my grief.
Old 07-28-2011, 05:26 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
When was the last time you did a tune up with plugs/wires/cap/rotor and filters?
Old 07-29-2011, 07:17 AM
mjp_t98's Avatar
mjp_t98
mjp_t98 is offline
And check the ECU for codes. It's OBD1, so it can have codes without setting the Check Engine light.
Old 07-29-2011, 11:33 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is online now
service the tranny as well. are you still running the stock exhaust? your cat converter may be starting to fail plugging the system.
how many miles are on the motor?
Old 11-06-2013, 10:53 AM
kitfarley's Avatar
kitfarley
I finally figured out my power problem. it was the pickup coil on the distributor. The truck finally stopped starting. I tracked it down to the pick up coil, replaced the dist. and I have my power back.
Old 11-07-2013, 08:38 PM
rla2005's Avatar
rla2005
rla2005 is offline
Glad to read you got it going. Thanks for reporting back with the cause/resolution!
1988fordf350
08-20-2016 01:34 PM
esbrian
07-16-2015 01:40 PM
mcancilla
04-27-2011 12:13 PM
Brian A
General Automotive Discussion
04-04-2004 04:37 PM
GoneTulsa
27
07-04-2003 08:36 AM
Quick Reply: '95 460 efi loses power towing slight grade
