He wants to make is truck sound like a Harley-Davidson! What's the point? Just get a Harley. An Electra Glide weighs about as much as my F250, and by the looks of the women passengers I see on most HDs, the bikes must have the same load capacity as my truck.
A Harley doesn't fire both cylinders at the same time, does it? The cylinders share a crank pin?
Yes the cylinders share a crank pin. And yes they do fire at the same time only there is a wasted spark. Ignition only happens on a compression stroke.
To the OP i love my Harley but i wouldn't want my SD to sound like my HD.
in theory, it would be possible to do to any engine.
take two cylinders that fire 270 degrees apart, and route them to a separate exhaust system, then run that straight out, while putting the other cylinders through a full muffler system.
the problem is that a vtwin sounds lumpy because there is not much momentum built up in the engine at idle, so the speed and timing are erratic.
the large heavy flywheel of a v6-8-or 10 cylinder engine will simply give you an even sounding two pulse drone, nothing at all like a vtwin
