Just got spindles back from maching shop and i was all ready to put my new king pins in. Got them installed sucessfully. So got everything put back together and now time to put wheels back on. I put drivers side, then went to go put passengers side on and the clearence from the jack stand wasnt enough. So what do i do? i use the jack, and jack it up just enought so i have clearence. Well, put the wheel on the studs then go to get the lug nuts and the wheels pops off kinda violently. My jack was leaking! so once i get the jack stand heighth right and wheels back on, it has a positive camber. I think i might of bent the spindle. At this point i was so frustrated i didnt take it apart to look at it. Im hoping its not the spindle and maybe the rim is bent or the studs? Could the axel of bent? Isn't that how that adjusted camber back in the day? Anyone have other ideas. Maybe it just looks funky, But im pretty sure the top of the wheel is out ward more than the bottom.
I assume you have an engine in the truck because without the weight of the engine you might have some noticible positive camber. But, if you do have the engine in, my guess is the wheel probably got bent. It takes a lot to bend a spindle or an axle...
If the wheel is bent, just rotating it will show the wobble.
It's possible that someone in the past had the axle bent to give correct camber with worn kingpins. Now that they are good, it's off. Seems unlikely but...
Does the wheel wobble if you jack it up and spin it? If not, it's not the wheel. If something bent just from a jack leaking down, I wouldn't want to drive the truck, just imagine what would happen if you hit a pothole
Havent had the chance to check will when i get home tomorrow . Hope it's just the wheel . Can anyone suggest a good size of wheels to go with I want to put radials on.
