glow shift guages any good?
I installed a four gauge pod on my a pillar two months ago. They work fantastic. No complaints. Took me 3-4 hours to install and got boost, exhaust temps, fuel pressure and transmission. And can switch through seven different colors. If they last, there a good deal. And yes, they came with what you need to make them work. Minus your tools, tap and die, some teflon tape, a three amp fuse and a power and ground wire to your battery.
Might as well give them a try... I have Isspro gauges with those silly "amp boxes" and i"ve had nothing but trouble with 2. I am about to just toss them and buy something else.
(coolant temp = goes haywire 90% of the time and is pretty much useless now)
(trans temp = does the same thing once in a while.... not very often but it is getting worse.)
I have checked and double checked all my connections to no avail... so it's gota be the boxes.
Isspro now has the EV2 without the amp boxes.
Isspro is made in the USA, right in Portland Oregon.
