1989 F-350 overheating..
3 things that I can think of....1st is how old is the water pump? I've seen some that have mega mileage on them where the impeller is nearly worn away, thusly not circulating the coolant- 2nd is somewhat related to the first-when cold, open the rad. cap, start the truck & let it run. While running, check to see if you're getting coolant flow in the rad.
Thirdly, check to see if you have a stuck caliper/dragging brakes. Pretty common and it'd make you run hotter than normal. Other things to check would be the fan clutch.
Does the truck overheat standing still idling or d you have to be moving?
Roger
Roger
Anyone who recommends checking your brakes because the engine is overheating should stop giving others advice on anything truck-related. That's one of the stupidest things I've ever read on this forum.
For the OP: What do you mean "getting hot too fast"? As long as the truck isn't overheating, it doesn't matter how fast the truck comes up to temp. Secondly, what kind of temps are you talking about? Do you have an aftermarket temp gauge? Are you checking the engine temps with an IR temp gun?
Do not use a lower thermostat. Your truck came with a 192 stat from the factory, and using anything else is just a band-aid on the real problem.
as far as thermostats go , I personally don't believe that any engine should run any hotter that 160 degrees . and for any work truck that i have had i always took the thermostats out , lots of times the trucks were standing still and running all day with on board generators and or manhole fans blowing all day ! the fan clutches were replaced with straight fans or clutch eliminators and bigger radiators to keep the engines cool , never had any problems !
now i am out in AZ in high heat and will swear by this way out hear ! other parts of country will be different , one way from the factory does not work in all cases !
Engines need certain amounts of heat to effeciently run.....And well..Not bein a dick...But I'm sure the guys from Ford that MADE THE VEHICLE knows best....Just saying...
you are right on the closed loop , lost several engines from overheating both diesels and gas with thermostats in them from the thermostats sticking closed , just last year the JD diesel thats in our air compressor would overheat , it had a built in safety to shut it off when it gets to hot and the thermostat housing was all filed up with gunk , cleaned it out and tossed the thermostat and it works great ! never lost a engine from running to cold even if they do stay in open loop !
some times circumstances and uses are not what any engineer thought about so one has to make things work for what they are doing !
all trucks are made for the majority of people and then you have people on the extreme end that will have to make adjustments to suit there needs !
when dodge came out with the cummins the engineers never thought about how hot it was in AZ and had many of diesels overheat cause the radiator was not even big enough ! so people had to have bigger radiator put in almost brand new trucks !
