Holley 600 carb on fe 360?
I think that's an "S", and not a 5 at the end of the PN in your post. Hence, 80457-S which is a a 600 cfm vac secondary with electric choke.
You'll need a 4 bbl intake... either a stock 4 bbl intake or Edelbrock Performer PN 2105. Opt for an open element air cleaner and filter.. it's a very cheap upgrade and worth a few HP, even on a 2 bbl. A 4-hole phenolic spacer is worth some low and mid-range RPM torque. To make the best of the 4 bbl induction however, consider installing headers and dual exhaust system before the carb upgrad.e
The throttle linkage may need some mods. Mine had a bell crank mounted on the intake in between two rods on either side. I had some extra Mustang parts and installed a single rod between the carb and the bellcrank mounted on the firewall.
I suggest doing a carb rebuild to establish a known good baseline.
Nick-1973-ford
07-17-2016 07:29 PM
xtraparts
08-29-2013 09:24 AM
Raptor119
20
08-11-2009 06:24 PM
76hi-boy
24
03-24-2005 11:21 PM
