Ford Truck Enthusiasts Forums
-   1967 - 1972 F-100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum39/)
-   -   Holley 600 carb on fe 360? (https://www.ford-trucks.com/forums/1085539-holley-600-carb-on-fe-360-a.html)
brigga72 07-23-2011 10:23 AM
I just aquired a holley carb with the list number 80457-5. My question is what, if anything, will I need to fit this to my 360 engine.
Thanks for any information.
HIO Silver 07-23-2011 02:30 PM
I think that's an "S", and not a 5 at the end of the PN in your post. Hence, 80457-S which is a a 600 cfm vac secondary with electric choke.
You'll need a 4 bbl intake... either a stock 4 bbl intake or Edelbrock Performer PN 2105. Opt for an open element air cleaner and filter.. it's a very cheap upgrade and worth a few HP, even on a 2 bbl. A 4-hole phenolic spacer is worth some low and mid-range RPM torque. To make the best of the 4 bbl induction however, consider installing headers and dual exhaust system before the carb upgrad.e
The throttle linkage may need some mods. Mine had a bell crank mounted on the intake in between two rods on either side. I had some extra Mustang parts and installed a single rod between the carb and the bellcrank mounted on the firewall.
I suggest doing a carb rebuild to establish a known good baseline.
mjshagnasty 07-23-2011 08:35 PM
If you want real cheap install opt for a 2 to 4 carb adapter they sell them at carquest.
