Need truck ID help
Need truck ID help
I searched, honest i did!
Can someone decode this for me please?
VIN: F70HVHH0423
Axle: 53M
Trans: CD
Body: DT8
Type: F701
I understand the wheelbase (inches) and GVWR numbers... just need help with the ones above.
Also the fuel tank has the following numbers:
D4TA 9002 UA
Cutler C 2701
I just need to know if this is compatible with diesel fuel (right now it's a gas truck).
Thanks much!
VIN: F70HVHH0423
Axle: 53M
Trans: CD
Body: DT8
Type: F701
D4TA 9002 UA
Cutler C 2701
Thanks much!
F70 = F700 (gas).
H = 370 2V or 4V (both are listed under H).
V = Kentucky Truck Assembly Plant.
HH0423 = 1980.
F701 = F700 (gas), 21,000 lbs. GVWR
DT8: DT = Heavy Duty Black Vinyl with Caramel Appointments / 8 = Conventional Cab.
CD: C = The first letter is meaningless / D = Spicer model 5052-A 5 Speed Direct Manual Transmission.
53M: 53 = Rockwell-Timken model H-172 Rear Axle / 6.17-1 / 15,000 lb. Rear Axle Capacity / M = Ford 7,000 lb. Capacity Front Axle with Power Steering.
ID number: D4TA-9002-UA = Ford part number: D4TZ-9002-U .. 75 Gallon Cylindrical Fuel Tank without Step.
Applications: 1974/80 F600/880 gas engines without Evaporative Emission.
Usually I woulda decoded all this jazz the day you first posted it, but "She who must be obeyed" and I were on vacation 7/21-8/7.
Now, I'm playing catch-up to the 100's of unanswered questions typed during this time span, and today, have been on FTE since 10AM PDT.
