2.5 Head Gasket?
Old 07-26-2011, 06:20 PM
Rackster's Avatar
Rackster
Rackster is offline
Self healing properties of the 2.3L
Tom,
I had a pal in Lawrenceville that had the Turbo T-bird and the thing would blow steam out of the exhaust. I don't know if it was due to a bad gasket or a bad head, but the car kept...truckin'! He ran it that way for over a year before trading it in.
Kevin
Old 07-27-2011, 12:08 AM
RhondaBruce's Avatar
RhondaBruce
RhondaBruce is offline
So I have a couple more questions regarding this engine replacement. The exhaust manifold to to exhaust pipe bolts broke off and I have a feeling the same will happen with the replacement engine exhaust bolts. Any suggestions to get these studs out when they break? I don't think there's enough meat on them to use a stud extractor. Also, should I install the original wiring harness or use the one with the replacement and splice in the only different connector? The original is a '98 2.5 and the replacement is a 2.5 from an '00 I believe both are automatics.
400 '77 F150 Ranger
05-11-2017 03:37 PM
Rusty Axlerod
12-22-2016 08:16 PM
wahlturfcare
12-02-2016 12:11 AM
ElMoco
46
11-28-2016 09:42 PM
88grandmarquis
11-03-2009 07:09 PM
Quick Reply: 2.5 Head Gasket?
