Now the fan is in the way....little help please
I left the fan on when I took off the old harmonic balancer and LPOP. I have the new LPOP in place and the Fluidampr was just dropped off by UPS. This thing is twice as thick as the factory one (and twice as heavy). With it being so thick now I have to undo the fan so I can get the 3/4" of clearance I need to install it.
How in the heck do you break it free. I put a C clamp on the pulley and BFW on the nut and hit the wrench with a 4pm hammer and the pulley just spins. I tried taking the 4 bolts that hold the pulley on but can't budge them with a two foot cheater on the wrench. Any ideas.
In lieu of having the proper tools....
An air hammer with a chisel tip will take it right off. Seriously. Stick the chisel end on one of the "corners" of the large nut and hammer away in a counter-clockwise direction.
If you don't have that, use a long pry bar and stick it between the hub and one of the four bolts while turning the nut with a wrench.
This is what you need, Autozone has a tool loan program and this is what I use.OEM/5 pcs. fan clutch wrench set (27141) | Fan Clutch Wrench | AutoZone.com
Don't get the two piece set the wrench is to small .
However, at this point what you really need are these two tools from Autozone. One holds onto the water pump pulley bolts and the other onto the fan nut, work them like scissors and the nut will come off. I had to squeeze really hard but it did work.
Photo courtesy of Robin (PaysonPSD)
Mike, hope the threading goes well for you today. Know how deep the threads are and measure on the tap so you don't break it off in the hole.
Needless to say, you are both right.
The Old Body Style trucks have right had thread on the fan as do the Super Duty F450/F550. On those trucks they have the addition of a belt driven vacuum pump unlike the electrical ones that our trucks have. So the belt routing is different and the water pump turns the opposite way.
Thanks guys, I wound up unbolting the the fan from the clutch. That apparently is the least of my problems. I boogered up the threads that are inside the crank for the dampener bolt. Went to NAPA and ordered a 16mmX2 tap and it will be in tomorrow morning. Keeping my fingers crossed.
I used an installer tool and didn't have any issues at all. Sorry to hear. Just make sure you get that tap started straight and you should be fine. Any idea of how much of the threads got messed up?
DieselHardware
17
07-20-2011 07:56 AM
