E4OD questions...
E4OD questions...
I have E4OD with 117k miles on it. I'm not sure with how a transmission truly works, never worked on one and had the urge to. But for some reason when i shift from park to reverse it goes straight to neutral than i have to shift back up to reverse. Also likes to go into 2nd gear before drive so i have to shift back up again, Any ideas? goes to neutral NO problem though. Is a little jerky when it shifts into gear, VERY SMOOTH on the road, but thought that was normal for this truck and transmission.
Thanks a lot man....And yes, it is....$$$.....
I'm not a big tranny guy......But I know a little bit from having one....
Mine would take a 1/2 to 1 second longer to go from Park to 1st...And would randomly pop out of gear into Neutral driving down the interstate....
Could be a MLPS sensor? IIRC what they were....That controls the tranny going in/out of gears....
Has the tranny filter/fluid been changed lately?
I have never worked on a tranny. So ill pass on doing the inners. Maybe a day when i have time ill pop open my learning motor tranny lol. But i can say that going from reverse to drive it takes a second, with park to reverse it goes to neutral first, than from reverse to drive it wants to go into 2nd generally but not always. Dad said it could be bad vacuum lines but i didnt know these had vacuum lines and if so where would they be at?
Ford Fuel Injection » How To Run a Self-Test Here is a link on how to check for any trouble codes. Might be worth doing. There are no vacuum lines to an E4OD.
SW may br right about the MLPS, also known as the transmission range sensor (TRS) also known as the neutral safety switch (NSS). Might be worth fitting an updated one. It is on the drivers side of the trans and the manual shift linkage connects to it.
However check for trouble codes first.
I think it might be an electrical problem like a fuse being burnt out or a connection not right. Have you checked the fuses? There is a fusebox in the cab and one in the engine compartment.
Nothing came up for MLPS or TRS but it said the E4OD has the NSS at autozone so i ordered it and waiting to pick it up from store. All fuses looked good, Is there a place from fuse to tranny that the wire splits at or is known for wearing out? Cant hurt to replace part for $30 anyway. Especially if it ends up fixin it.
no places that I know of other than the fuse boxes to check. I will see if I can find a wiring diagram of the two connectors on the tranny. The OD wire goes to there and if you can find it there and then find it in the cab, maybe you can test to see if the wire is disconnected.
I think it is +3v that goes into the OD wire so when the tranny detects that voltage, it turns on the OD. If you can find the wire and then (maybe) test it by giving it what it needs (+3v or maybe grounding the wire) then you should be able to drive the truck and see if it goes in to OD or not.
