300L6 Rebuild
300L6 Rebuild
I have a bone stock 1983 300. I'm going to send it to get rebuilt soon. I want to put a more aggressive cam in it and a 4 barrel intake manifold from Offenhauser and an exhaust manifold from an EFI 300 because they are slightly bigger. I'd like some suggestions on what cam I should put it and what carburetor CFM I should go with. I have the BW T-19 transmission but I'd like to put a 5 speed behind it at some point. It's pretty much a cruiser with occasional towing/hauling.
I'm not sure yet, I'll probably bore .030 over and rause the compression a bit. Any recommendations for pistons?
There are only two pistons readily available that will give you the highest compression.
If you deck the block so the pistons are even with the top of the block at TDC the compression ratio will be 8.7
FORD Silvolite 1186H.030 Silv-O-Lite Hypereutectic Pistons | Summit Racing
FORD Silvolite 3171H.030 Silv-O-Lite Hypereutectic Pistons | Summit Racing
I highly recommend Iskenderian (who I personally know to this day physically tests/inspects every single valve spring before it leaves the shop) & Crower & Chet Herbert & Lunati...all are family owned, been grinding cams for decades, and both will even re-grind your oem cam if possible- saving you even more $. Ron (the son has had the shop for several decades now) has invested in digital computer cam grinding equipment so they can literally vary a cam profile in minutes or combine the best of 2 different profiles to meet your needs.
You will read alot about Clifford Research (6=8)..... the father started off in a small community outside of lake Arrowhead called Cedar Glen. I worked at a gas station he would buy from and in general, he was basically a nice guy, but he liked his alcohol drinks.... so when he would come in, sometimes he was ok other times well, you just worked to get him out of there. The son took over the business after he passed away eventually moving to Temecula IIRR but in short, things may have changed but, if there were specialty parts (adapters, etc.) that you needed he was the go to place, otherwise there was no real benefit to purchasing from them IMHO.
Seanmac1007
08-10-2023 06:55 PM
tex_mex1911
07-02-2022 12:43 PM
WD4B
07-09-2012 10:44 AM
Stephens
01-01-2002 02:40 PM
