Duraspark 2 mpg tip
Old 08-10-2011, 09:08 PM
Vanaroo's Avatar
Vanaroo
Vanaroo is offline
Will the recurve job do anything for a stock engine or this more for modded engine?
Old 08-16-2011, 12:07 AM
seattle smitty's Avatar
seattle smitty
seattle smitty is offline
"Your results may vary". Recurving is even more important in modified engines, but I'd guess this is for a stocker. Nearly any smog motor of the '70s and '80s will see performance benefits from a similar proceedure.
Old 08-20-2011, 04:38 PM
Vanaroo's Avatar
Vanaroo
Vanaroo is offline
Thanks SS! Hey, I don't mean to hi-jack this thread but I've got a duraspark question I'm hoping someone can answer.
I installed a duraspark 2 but I kept my tfi coil. Its been running great. Then I checked out the gofastforless.com site and he says the tfi coil won't work with the duraspark 2. Am I running the risk of burning up the module or?
Old 08-20-2011, 09:28 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Sw1tchfoot is offline
I believe the problem is that the timing is computer controlled on a TFI dizzy.
Old 08-21-2011, 10:22 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
As far as I know, the coil used with the TFI setup is just a coil. If you have the DSII distributor and ignition module, everything should be okay.
Old 08-21-2011, 02:38 PM
Sw1tchfoot's Avatar
Sw1tchfoot
I wasn't thinking, I though he said he kept the old distributor.
The coil should be just fine to use.
Old 08-24-2011, 10:11 AM
Wyowanderer's Avatar
Wyowanderer
Wyowanderer is offline
The TFI coil will work with DSII, but not for very long. Better to replace it with a round Ford coil.
And ignore the gofastforless site. It's a fix for a problem that doesn't exist.
Old 08-24-2011, 10:32 AM
nevrenufhp's Avatar
nevrenufhp
nevrenufhp is offline
Going from points to a dspark, the go fast for less would be a simplistic wiring option.
Old 08-24-2011, 02:02 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
While I admit wiring is my strong point(if I have one), I've never understood why people think it's so hard to wire a DSII. Plugs are available at NAPA if needed. After about 76 it's plug and play. Two simple wires back to ignition switch and it's done.
Old 08-24-2011, 04:06 PM
nevrenufhp's Avatar
nevrenufhp
Wiring is mine too. I didnt want just a dspark though. I went with an aftermarket box/ module to maximize its potential.
Old 08-24-2011, 04:48 PM
Vanaroo's Avatar
Vanaroo
Vanaroo is offline
That's why I switched to duraspark 2. I had the tfi4 system and it looked fairly new but the more I read about it (I'm new to this stuff) I learned the timing was controlled by the computer. I could see that all the sensors and emissions stuff had been removed. I figured the computer was no longer getting the correct info it needed to adjust timing with. So I removed the computer and the tfi distributor and added the duraspark 2. It was an easy swap even for a beginner. I had the ds2 coil from the donor vehicle but I tried just plugging in to my old tfi coil and it worked so I kept it. I'm trying to squeeze all the mpg's out of this van that I can and that's what got me interested in the recurve mod. Last weekend I put in a can coil and I must say, I believe I notice a difference. I think the tfi coil ran better for me but I don't want to be frying ignition modules.
I'm learning a LOT on this site. Thanks guys for all the great info!
Old 08-24-2011, 08:19 PM
Harte3's Avatar
Harte3
Harte3 is offline
  #28
Old 09-21-2011, 01:48 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Does anyone know if all Reluctor arms are welded equally? I swapped mine out like a month ago for another one that I limited the advance on (so I wouldn't have it sitting undrivable), but I never rechecked the timing. I just made sure I limited and used the same side so it wouldn't be 180 degrees off.
You know, you like look under it and you can see that the pieces are welded together; so I just wondered if they may possible that out of all the reluctors they made that different ones could be a couple of degrees off?
  #29
Old 12-03-2011, 05:54 PM
graflexmaster's Avatar
graflexmaster
graflexmaster is offline
Originally Posted by BaronVonAutomatc
I've never used them before, but I'm going to send my dizzy to Advanced Distributors for a rebuild/recurve. They sound like they know what they're doing.
I've known Jeff at advanced dist for several years..and he is considered in many circles as the #1 Dizzy guru. I would recomend his work to anyone...
I would send my own dist work to hin, but I have my own Sun Dist mach. and do my own as needed.
  #30
Old 10-25-2014, 09:43 AM
juit's Avatar
juit
juit is offline
hi
Im trying to do this mod on my 302 2121 edelbrock 600 cfm carb
I left the lite spring only
One is 10L And the other 15 L with 1 g weights
idle 12
1500 18
2000 21
2500 25
3000 30
3500 35
idles the same in city rich mixture
at 65 miles 5th gear the AFR leans too much that it dissapears :0
way too agressive
feals very strong at launching from 0
no pings no hessitations
but smells a lot of gas fumes because of the lean mixture
should I wait for the mr gasket springs?
after it warmed I had some problems starting it so I backed out to 12 again or I could leave it at 10 like the mechanic left it
What springs should i use?
Thanks
Quick Reply: Duraspark 2 mpg tip
