Blocked Cat Converter
Old 07-15-2011, 10:25 AM
stewbeans22's Avatar
stewbeans22
stewbeans22 is offline
Question Blocked Cat Converter
Hey guys I have a 2006 F-150 with the 5.4L. I got the check engine light and the computer says catalyst defeincy bank 2. So I assume the passenger side converter is blocked. Is there anyway to either take out the cat and replace with a peice of straight pipe and bypass the o2 sensors or take the cat out of the housing and put the housing in and then bypass the o2 sensors. Help. Thanks
Old 07-15-2011, 08:04 PM
Djack04F150XL's Avatar
Djack04F150XL
Djack04F150XL is offline
I'm sure Bank 2 is the driver's side 5-8. You will need to replace the cat(s) to correct the code. They usually go bad for a reason also. Bad injector, misfiring plug, etc. You can remove them to inspect them if your inclined to. They were on backorder but there are more sources now.
Old 07-15-2011, 09:15 PM
stewbeans22
How much do they usually run.
Old 07-16-2011, 12:08 AM
Djack04F150XL
Summit Racing prices are: Driver side 2wd run from a #53651 Walker @ $251.99 to a #93664 Magnaflow @ $341.14; Passenger side 2wd from #50543 Walker @ $389.99 to a #47167 Magnaflow @571.95. 4wd are usually a little higher. This converters are 49 State legal but are not for sale in CA. Different cats for CA.
Old 07-16-2011, 12:18 AM
stewbeans22
Cool thanks. Still think it would be cheaper to cut them out and figure out how to bypass the o2 sensors.
Old 07-16-2011, 01:18 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
How many miles?
Cats are covered by a long warranty. 8/80 for cats.
You can't bypass the sensors. You have to buy some simulator that feeds the false info into ecu.
Why would they fail? Have you done an exhaust pressure test? At about 4 min on the second video they finally show the backpressure, and they only want 1 psi backpressure on this one.
http://www.youtube.com/watch?v=9TlygJMxTps&feature=related[/URL]
Finally at about 4:00 they hook up the gauge. 1 psi backpressure is what they were looking for. You need to pull a sensor ahead of the cat in your case:
http://www.youtube.com/watch?v=4QvR5Nqun4g&feature=related
Old 07-16-2011, 09:14 AM
stewbeans22
It has 117,000 miles. I think the cause is that I had some stuttering problems and the code said it was an ignition misfire. I changed the plugs and it ran fine. Now the cats are blocked. How much do the simulators run.
Old 07-16-2011, 09:15 AM
2Fords1Jeep's Avatar
2Fords1Jeep
2Fords1Jeep is offline
Cat may be covered under warrantee with the emissions system, or if it is related to a defective injector.
Old 07-16-2011, 05:57 PM
85e150's Avatar
85e150
He's past the 8/80 on the cats.
To the OP: Did you do a backpressure test?
Simulators? just google it, you'll find millions. OK, hundreds, like this:
O2 Sensor Simulator
MAGNUM Car - Truck Performance Chips - Oxygen O2 Sensor Simulators
Check out who you buy from, these seem to smell of snake oil and I wouldn't doubt some are junk.
Old 07-16-2011, 06:42 PM
JesseJFX2's Avatar
JesseJFX2
JesseJFX2 is offline
Don't assume it's a blocked cat, like others said, do a pressure test... You could just have have a defective oxygen sensor (hell there are 4 of them!). It takes quite a bit to plug a cat so look into the problem a little further before you start trying to trick the computer or go hacking away at your exaust system.
Old 07-16-2011, 08:42 PM
stewbeans22
No I did not do a pressure test. Not sure how to.
Old 07-16-2011, 11:45 PM
85e150's Avatar
85e150
Uh, post 6?
Old 07-17-2011, 01:08 AM
stewbeans22
Yeah you are right. After I posted it I realized the video was posted. Brain fart.
Old 07-17-2011, 01:16 AM
stewbeans22
system.
I guess even if the cats are ok and an o2 sensor is bad that would make the truck idle rough anyway. When the truck is idling it kind of shakes and sounds like the truck is starving for fuel. I don't know I'm ready to throw a match to it. Lol
Old 07-17-2011, 01:25 AM
stewbeans22
If I did the back pressure check, which o2 sensor do i take out and check pressure at or do i check it at each sensor. What kind of readings should I be looking for.
Quick Reply: Blocked Cat Converter
