Completely ruined my middle row seats:(
Never had i folded them down and i ignored the step guide on the side of the seat.
I pulled the cushion out like you are supposed to do. But then i pulled the wrong lever (which is supposed to be only used when tilting the seat to let people in) and ppulled the lower lever to push the seat down. i should have known i was doing it wrong because i had to force the seatback into the down position with some strength and yet it still would not lock. I gave up and put the seat back up and noticed that the bench kept sliding forward and wont lock. So now anyone who sits behind me will be sliding back and forward with the motionm of the vehicle.
I took alook at what i may have damaged and its a rod attached to a bracket that engages the lock.. the rod and latch which holds the rod are completely bent.
Read and follow labels to the idiots like me.
Just for kicks, you could accelerate and brake really hard...especially when they're drinking a beverage. That shoulder belt would be a real pain since it's fixed on the pillar and the bench sliding back and forth...
If you're a bit handy, you may be able to re-straighten it with a pair of pliers. May have to pull the seat and turn it upside down to get at it but as long as the metal didn't break, you could give it a shot. I suspect the job won't be that bad, just a little time consuming. Also wear gloved, there tends to be a lot of sharp parts under the seats.
Bet swallowing your pride was harder than the fix may be
Ranger431
03-17-2012 03:34 PM
Critterhunter
1983 - 2012 Ranger & B-Series
04-21-2010 10:12 PM
