5.0 rebuild
on
Right.. so with that reality check your next question is.. "so how much HP can I make within budget?" 300hp isn't that hard or expensive, maybe a little more with GT40 heads or some home porting on the stock E7s. Rebuild the bottom end to stock spec with 0.030" over pistons, get the heads ready, install the Comp 35-349-8(like a HO cam with more lift, and yes it's SD friendly), bolt on headers and a complete exhaust system, and there you go. I'd also suggest installing 4.10 gears in the rear axle and some traction bars, and a shift kit in the trans and then you're all set to go rice hunting.
I like your thinking. Not too extreme but enough.
on
Here you go. BTW... it's the cam I have in my 5.0 right now.
COMP Cams 35-349-8 - COMP Cams Xtreme Energy Camshafts - Overview - SummitRacing.com
You don't need the 351 computer, just "Cross-wire" the injectors, and they use the same plug for the distributors. Thats what I did. I had a 5.0 in a 89, and I put in a 351 and kept the same computer.
on
Sorry but.. larger injectors will not cooperate with a stock SD computer, and if someone did all that and only got 330hp they wasted their money because you can get nearly 300hp without the heads, intake, TB, and injectors.
Do you know the specific order? or what injectors are in each batch?. It would seem 5.0 or 5.8 wouldn't really matter if they fire in batches
#29
#30
Its supposed to evenly distribute fuel in the intake
Because of this, Why should it matter 5.0 or 5.8?
