1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Loosing transmission fluid
Old 07-08-2011, 04:11 PM
omnicare's Avatar
omnicare
omnicare is offline
2010 f250 4wd diesel. 36000 miles. I am having to add 1/2-1 pint of transmisson fluid every 500 miles or so. I had it serviced at about 25,000 miles because i am pulling a fifth wheel RV. I have had it in the dealership and they can find nothing at all. I see no leaks either. No one seems to know where it its going? It has been suggested that the seals could be bad and it is going into the transfer case? Any ideas?
Old 07-08-2011, 04:24 PM
pduffy211's Avatar
pduffy211
pduffy211 is offline
That is a crap load of fluid, you should see it someplace. You can check the level in the transfer case to start but I'd start parking it in the same (hard covered) place all the time and watch for drips.
Old 07-08-2011, 04:33 PM
omnicare's Avatar
omnicare
omnicare is offline
Thanks pduffy211. haven't seen the first drop on the ground. The underbelly is clean. I'm putting up on the rack tomorrow to check the transfer case level. Ever heard of that happening?
Old 07-10-2011, 11:13 AM
pduffy211's Avatar
pduffy211
I'm not going to say it isn't possible but that much fluid transfer is going to come out of the transfer case seals or vent sooner or later. Might check this thread for other ideas.
F250 Transmission Leaks when backing - Ford Forums - Mustang Forum, Ford Trucks, Ford Focus and Ford Cars
Old 07-10-2011, 11:21 AM
EXv10's Avatar
EXv10
EXv10 is offline
On some vehicles the oil can be sucked into the engine through a vacuum tube/hose and burnt but not famiar with this setup.
Old 07-10-2011, 02:42 PM
omnicare's Avatar
omnicare
omnicare is offline
Sucked into the engine? Wouldn't there be smoke or something? I had it at the dealership in Roswell NM yesterday. The underbody was totally dry and the oil level in the transfer case was correct. NOBODY AT THE DEALERSHIPS HAS A CLUE. Should this be a warranty issue now should a file some kind of a claim?
Old 07-10-2011, 04:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
That system went out a couple decades ago. It can't happen on electronic transmissions.
Liquid_force
05-19-2014 05:31 PM
teddeshong
04-30-2011 02:11 AM
B 3000
Escape & Escape Hybrid
02-18-2010 06:41 PM
tonyford
23
01-08-2006 08:44 PM
Quick Reply: Loosing transmission fluid
