Best way to clean the engine?
The 7.3 is a messy eater.. I was just wondering if anyone had any suggestions on a good SAFE way to clean the engine compartment.
The engine compartment on my F150 got sprayed down with water from the hose once and it caused all kinds of shorts (Honking the horn made the hi beams flash for example) I never found out if the problems self resolved because it was totaled later that night in an unrelated accident.
Anyway... wondering if there is a way to clean up the engine. Planning a foil delete and I have a CCV in right now, but I'm going to return it to stock after I get some IC boots from Clay.
Use a flash light ang look on top of the engine under the turbo. I'll bet you have oil in the valley back there. It is probably a HPOP line leaking or turbo pedestal seal. Almost never the rear main.
The CCV is a black dog house that is under the intake tube half way between filter and turbo. In a stock set up it is routed into the intake tube.
Power purple also works well I've found the best results on a hot engine, if you have your boost tubes off then easy off oven cleaner does a really good job in the valley on the thick crusty stuff but it etches any aluminum so if it's shiny take it off or it won't be and keep it out of the alternator but it cleans nice And the hotter the engine the better the clean!
i soaked everything down with simple green mixed with some water....probably about 50/50 then hosed it down. after that i spray WD-40 on everything to protect it. there are a lot of other post-wash sprays but WD-40 is non-corrosive and is used in a lot of electrical panels etc that get exposed to water once in a while. learned that on a job site from one of our electricians that does our interconnection on the wind turbines.
for the nasty stuff i use carb cleaner or brake cleaner and a toilet brush. you'll probably need it for the area near the IC up pipe when you do your foil delete. i had a nice thick film of grime in there.
I've got some simple green. I love the stuff. What do I need to protect when spraying down the motor?
Yes, the CCV Mod does keep the engine clean, when using rubber IC boots. But Clay has some silicone ones, which, if I am not mistaken, should not be susceptible to degradation from oil residue. Also, the CCV Mod is not legal. At least here in CA. So come smog time (Granted I have 2 more years for that) I will have to remove it anyway.
