Well I put the 3.55 gears in made absolute no difference no power still same rpm shift points it was just waste of money I guess the m5od makes all the power
Well.. and automatic trans does consume a bit more power so all else being equal the manual will feel a bit stronger. On top of that the M5OD had 5 forward gears versus 4 with the E4OD and the only gear that matches between them is 4th in the manual and 3rd(drive) with the auto.
In 4hi on a packed dirt road? Yes.. there's simply too much traction and not enough motor. On lose soil it should be able to break them lose but it won't spin them for very long. This is a 150hp motor after all.
