Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-03-2011, 07:55 PM
trvlrerik's Avatar
trvlrerik trvlrerik is offline
Garage is empty, add now
trvlrerik is starting off with a positive reputation.
Aftermarket fuel tank questions/advice
I have an 08 F350 short wheel base, with 6.4 Powerstroke and I want to add more fuel capacity so I can pick when I want to fuel up, rather than worry about if I am in range of a fuel station.
I have decided that I am going to get a 50 to 60 gallon transfer/aux toolbox in bed tank that I can re-use from truck to truck.
There are many options that effect the cost and weight of the tank. Are internal baffles a must have option? It seems to me that there is a variance of weight in the tanks of nearly 100 lbs, the lighter tanks are more expensive, but have no baffles in them. Is adding 400+ lbs of fuel and 100+ lbs of tank to an F350 even that big of a deal anyway?
My fifth wheel adds about 3000lbs to the bed, and I have Firestone ride rite bags installed. Thanks for any advice.
  #2 (permalink)
Old 07-03-2011, 09:08 PM
lakedweller's Avatar
lakedweller lakedweller is offline
lakedweller is starting off with a positive reputation.
I plan on doing mine as soon as I can get my wife off the $800 for the tank/tool box...
__________________
George
2011 Ford F350 Lariat, 4x4, 6.7 PSD, SRW, CC, Short Box, Reese 16K slider
2009 VW Jetta TDI
2006 Golfstream Sedona, 34', 5th Wheel, Reese Sidewinder pin box
  #3 (permalink)
Old 07-03-2011, 10:35 PM
dyoungen dyoungen is offline
dyoungen is starting off with a positive reputation.
I bought a 91 gallon tank that fit my 1987 F250 from either Harbor Freight or Northern tool. From what I hear if you have a tank over 100 or 110 gallons you have to get all kinds of labels saying what your carrying.
  #4 (permalink)
Old 07-12-2011, 01:27 PM
n4aof's Avatar
n4aof n4aof is offline
n4aof is starting off with a positive reputation.
Quote:
Internal baffles are not important IF (and only if) you only operate with the tank either full or empty.
The weight itself won't be an issue with a properly mounted tank at the front of the bed of an F350 -- the problem comes when the fuel sloshes from side to side during a turn, especially an S-curve or similar maneuver.
When the tank is either full or empty, there is no problem with the weight shifting, but if you go into a turn with half a tank of fuel, the weight will shift to the outside -- the quicker the turn, the faster the weight shift and the more drastic the effects.
The absolute worst case would be a half-tank, and you suddenly need to swerve around the non-driving-fool who just pulled out in front of you or who just had something drop off his vehicle.
The weight is well above the truck center of gravity, so having it shift suddenly can make maneuvers very interesting.
__________________
2004 F250 CC V10
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should, use the WD-40.
If it shouldn't move and does, use the duct tape.
  #5 (permalink)
Old 08-19-2012, 11:39 AM
srteach srteach is offline
srteach is gaining momentum as a positive member of FTE.
He is dead correct. VERY INTERESTING.
Diesel fuel has a weight of 6.951 pounds/gallon on the low end. You are talking at least 347.55 pounds (50 gal tank) transferring to the outer radius of the turn all at the same time. That, multiplied by the distance above CoG, along with tongue weight of the trailer makes one hell of a mass shift. The less the mass shifts, the less effect there is on control. Having the weight that far above the Center of Gravity (CoG) can actually cause the truck to roll over in emergency situations.
This all depends on tire inflation, other weights and their placement, suspension components and their condition and a myriad other factors. Best and safest is to have baffles in the tank to prevent slosh.
__________________
Darrell, PAA#131
The Blue(ish) Beast. 7.3 manual, 6637 Mod, Hutch mod on a steel aft axle tank, pre-pump fuel filter, coolant filter, LED rear lights, HPx, front axle rebuild, transfer case replaced, rear (clear 1 piece) window replaced with privacy manual slider
  #6 (permalink)
Old 08-26-2012, 03:19 AM
RPM371's Avatar
RPM371 RPM371 is offline
2006 Ford F-350
RPM371 is gaining momentum as a positive member of FTE.
I'm looking at one of these:
Click the image to open in full size.
The lid conceals the filler cap and and adds an extra bit of security at $4 a gallon.
(and it has baffles)
__________________
2006 F350 XLT 4x4 Crew Cab, 6.0 Powerstroke, ARP Studs, OEM Head Gaskets, Performance Machine Coolant Filter, Sinister EGR Delete, High Idle Mod, Scangauge II, SCT w/ Matt's 8K Tow Tune, FICM by Ed w/Atlas 40, Firestone Ride-Rite Air Suspension, B&W Turnoverball, Michelin LTX A/T 2 LT245/75R17, Galaxy 939 w/Texas Star amp, SiriusXM XpressRCi, Ouku 7" Flip Down HD Touch Screen/DVD/CD/Nav/Bluetooth/USB/SD/Cam (it plays the radio, too).
  #7 (permalink)
Old 08-26-2012, 10:24 AM
That looks like a good tank, RPM.
BTW, I designed a tank for my dad. It was 77.5gal, the width and depth of the bed and had 5 baffles (1 side to side, 4 front to back). He reports no issues with slosh weight from it.
I had to design it to fit under a side load ATV rack / bed cap he had designed. He needed access to the tank with 2 ATVs on the bed and the cap closed. Made an interesting design challenge.
__________________
Darrell, PAA#131
  #8 (permalink)
Old 08-26-2012, 10:54 AM
RPM371's Avatar
2006 Ford F-350
I like that design better than the 2 piece "Lego" setup I see with most tanks and toolboxes. Not only does it advertise you have fuel to steal, it makes it easier to get to.
The only drawback to the combo design is a smaller toolbox.
__________________
Tags
1999, 2006, aftermarket, baffles, bigger, f250, f350, ford, fuel, gas, market, tank, tanks, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
