Need info on 1995 f350 Power Stroke Turbo Dually
Need to know what type of automatic transmissions came in the 95 crew cab. I got a 91 ext. cab 460 EFI w/E4OD that a tree took a like n to and I found a 95 crew cab PS Turbo that needs an automatic transmission. Would solve my problem if i could swap them out without alot of major changes. It would also help with my gas mileage!!! Any help would be appreciated. Thanks.
on
it's an E40D as well,however its not a ford bell housing at all.it bolts behind the navistar international diesel,and isn't the same as the BB gas engine.
even if ford did build their own diesel engine back then,they would have made a different bolt pattern for sure so transmissions couldn't be swapped.......you know ford.
Received 3,117 Likes
on
Chapulin
01-23-2013 04:24 PM
JTATMAN
05-08-2006 02:47 PM
