1997 f150 4.6 overheating
Old 07-06-2011, 10:41 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Take the cap off and just let it run until the thermostat opens(the upper rad hose will get hot). Make sure the coolant is to the full level then use this tool to check for a bad head gasket. ANY color change means there is a leak. I tap into the vac line on the fuel pressure regulator.
Old 07-06-2011, 03:06 PM
five.fold's Avatar
five.fold
five.fold is offline
thanks for the tip. will keep you posted.
Old 07-08-2011, 06:33 PM
five.fold's Avatar
five.fold
Just tested with my new tester-3 times-ALL BLUE ALL THE TIME. Did notice the lower radiator hose collapsed (as well as the upper) while i was testing. Could it possibly be that the lower hose collapses the first time the t-stat opens because of the pump suction, causing my problem, then once the system has built up pressure from the heat, the lower stays open because of the pressure, hence no overheating till the engine is completely cooled off?
Old 07-08-2011, 06:37 PM
five.fold's Avatar
five.fold
I drove this truck all day today. first thing this morning, gauge pegged. pulled over, turned off engine, waited 10 seconds or so, restarted, gauge needle fell like a rock, drove the rest of the day(app 30 miles around town, stop/start, here there), no problems whatsoever!
Old 08-01-2011, 06:25 AM
five.fold's Avatar
five.fold
update-Installed a 180 t-stat, no problems of any kind since. live in midwest-kc area, 98 degree outside temps, runs like a sewing machine, good reading on gauge-about 1/3 of the way up.
Old 08-02-2011, 07:33 AM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
Could be....more likely, the radiator hoses are weak and & cutting off or restricting currulation when in colapsed state. they shouldn't colaps
also the 180* T stat, is bit low...and may upset the running parameters a bit...run rich on cold starts. this may not be a real issue until colder weather hits, as it with run rich longer due to colder outside temps.
Old 08-02-2011, 09:29 AM
five.fold's Avatar
five.fold
enriched-Thanks for the input, think I'll live with the 180 till cold weather, its not that big of a deal to switch out t/stats. thanks to all for the input.see ya down the road! (I'll probably be in a CHEVY, though!)
Old 08-25-2012, 10:54 AM
LANKY's Avatar
LANKY
LANKY is offline
3/16ths hole in thermostat
Hey first time here, I had the same problem it started when I changed the thermostat. What I did to fix was took the thermostat back out and drilled a 3/16ths hole in the thermostat outer rim that lets the water flow thru and haven't had any problems since.
Wingit929
1999 to 2016 Super Duty
10-19-2016 01:55 PM
truknoob
29
08-26-2016 12:31 PM
KJNDIVER
61
06-02-2016 08:33 AM
hadam
19
01-04-2016 12:00 PM
Mike Parker
New Member Introductions
11-07-2015 12:23 AM
Quick Reply: 1997 f150 4.6 overheating
