1999 F150 4.6L - Injector questions
Old 06-30-2011, 02:22 PM
trailor's Avatar
trailor
trailor is offline
Well first and foremost I need to know what kind of injectors come in a stock 1999 4.6L F150 (keep in mind, this model doesn't have COP's, whether or not that makes a difference). By what kind, I mean are they EV1 or EV6?? I have searched and cannot get a definite answer. Also, just wanted to double check, they are 19lbs./hr injectors, correct??
I probably have some further questions, but I am at work right now so my time is limited, and getting this answer alone will get me started on my repair process. Thanks in advance for your responses!!
Old 07-01-2011, 01:40 PM
trailor's Avatar
trailor
trailor is offline
BUMP.. anyone?? need to get the parts ordered soon...
Old 07-01-2011, 02:22 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
I don't know what your truck has now but they are not critical for injectors as long as the plug is correct.
Look at the ROCK AUTO site for injectors for F150 4.6 and you will see a whole bunch of alterate Ford part numbers that can be used.
Look on yours for PN and color.
Just curious what is the reason for changing them other than general maintaince?
Good luck.
Old 07-02-2011, 08:15 PM
trailor's Avatar
trailor
trailor is offline
Good luck.
Not trying to replace, trying to thoroughly clean. And to do that, I need a parts kit that supplies new filters and o-rings, as well as a test bracket. In order to buy this kit, I first need to know if I have EV1 or EV6 because the filters and o-rings, as well as the test bracket, are different sizes.
Old 07-04-2011, 12:15 AM
keyul's Avatar
keyul
keyul is offline
You may be able to visually match it, take a look at the image below under body style, or go to:
Ford Racing Performance Parts - [2010 Catalog]
And at the bottom type in page 222
If that dont work, call your local parts/service department and they should be able to tell you:
Old 07-04-2011, 02:05 PM
Phillip Guidry's Avatar
Phillip Guidry
Phillip Guidry is offline
Send `em to a local injector shop !
I send all the injectors that I want cleaned to my local injector shop... they not only do diesel but as well as gas injectors ...they clean them with an alkaline solution while flow testing them at the same time on their bench machine... then they put new top hat filters and o-rings before they send them back to me... I get charged between 25-35 dollars per injector
Old 07-05-2011, 09:19 AM
trailor's Avatar
trailor
trailor is offline
that does seem like a tempting idea, but the kit i'm looking at online with all the new filters, o-rings, and test bracket, costs ~$25, and the UV jewelry cleaner costs ~$30 at harbor frieght, and a bottle of concentrated fuel injector cleaner costs ~$2. So for a total of ~$60 i find that to be a bit of a cheaper DIY alternative.
thanks for the responses guys. fortunately, after doing some other work to the truck first, i was able to find that a faulty injector was not causing my problem, but i will keep this thread tagged in case i ever need to do that job. thanks!
moonley
12-17-2016 03:01 PM
ThorM465
1983 - 2012 Ranger & B-Series
24
07-28-2016 03:34 PM
Piolet
04-23-2012 10:49 PM
Josh88Ford
02-21-2011 12:52 AM
Billy B.
1997 - 2003 F150
09-15-2010 07:12 AM
Quick Reply: 1999 F150 4.6L - Injector questions
