OLD DECODES
#392
Hello sir, I was wondering if I could have a moment of your time to help me decoad my vin on my 1987 f800? I'm really interested in what ring and pinion I have and any other information would be appreciated. The vin is 1FDXT84A5HVA24828. Again thanks for your time.
#393
Hello sir, I was wondering if I could have a moment of your time to help me decode my VIN on my 1987 F800?
I'm really interested in what ring and pinion I have and any other information would be appreciated. VIN: 1FDXT84A5HVA24828
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
X = Class 7 Air Brakes, 26,001-33,000 lbs. Gross Vehicle Weight Rating range.
T84 = F800 (gas).
A = 7.8L (476 cid) V8 (gas).
5 = Check digit, FoMoCo use only.
H = 1987.
V = Kentucky Truck Assembly Plant.
A24828 = 1987 Numerical Sequence of Assembly, the trucks specific serial number.
#395
Would like my vin decoded please, also need all the brake lines and associated parts from the rear frame rail up to the wheel cylinders.
vin. 1FDPK74N2EVA15872
thanks for your help
#396
P = Class 7, Hydraulic Brakes - 26,001-33,000 lbs. Gross Vehicle Weight Rating range.
K74 = F700 Diesel.
N = Detroit 8.2L 8 cylinder Diesel.
2 = Check digit, FoMoCo use only.
E = 1984.
A15872 = 1984 Numerical Sequence of Assembly.
#397
[QUOTE]Quote:
Originally Posted by*josh6431*
Would like my vin decoded please.
1FDPK74N2EVA15872
K74 = F700 Diesel.
E = 1984.
A15872 = 1984 Numerical Sequence of Assembly./QUOTE]
Thanks for the info, any idea on the parts? The main part number I need is for the rear brake connector/ ditribution tee.
1FDPK74N2EVA15872
K74 = F700 Diesel.
E = 1984.
#398
C600 numbers please!
Hi Number Dummy,
Thanks for helping us all out with our data tag info!
It's greatly appreciated. You have helped me a few times. After many fortunes won and lost, and vehicles come and gone, I'm getting a c600 Friday. Owner says it's a 67, but after looking at another vin you decoded, I'm not sure.
Vin is C61DUA74064
Thanks I appreciate it!
Vin is C61DUA74064
#399
Hi Number Dummy,
Vin is C61DUA74064
Vin is C61DUA74064
C61 = C600 Tilt Cab.
D = 330 2V Heavy Duty FT engine.
U = Louisville KY Assembly Plant.
A74064 = 1967, assembled in January 1967 or 1976.
Kentucky Truck Assembly Plant (Assembly Plant code V) opened in 1969, where C Series were assembled from then on.
1968 was the first year that the door emblems have yellow reflectors made as part of them. No yellow reflectors, it's a 1967 or earlier.
#400
I'm not sure either as this VIN could decode to either a 1967 or a 1976.
No reflector on door badge. It has the older trapezoid shape emblem the the FORD letters above it, so must be '67.
Also, the guy I bought it from thought it was a 390, so that was another fact you corrected.
Thanks again!
#402
1968 f800 with marmon herrington conversion
I am looking for any information regarding the hydraulic front drum brake hardware kit. It has 16x2.25" shoes. Any help will be geatly appreciated. Thank you
#404
Former City of Denver Hot Asphalt (Tar) Applicator
