1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
A/c compressor clutch
Old 06-25-2011, 12:44 PM
Ridenred333's Avatar
Ridenred333
Ridenred333 is offline
Ok a/c wasnt working took it to a mechanic told me the the compressor was missing a clutch he recommended i put a new compressor. Is it possible just to put a new clutch in it and if so do i have to remove the compressor to put the clutch on it. Once again thanks.
Old 06-28-2011, 08:38 PM
Ridenred333
anyone have any ideas on this
Old 06-28-2011, 09:25 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
How the compressor can be missing the clutch and the belt is still on?
I guess front bolt come off and the clutch is not engaging the compressor? The clutches used to be sold as separate item, but times are changing and now dealers want to sell you whole assembly when you need a washer, or seal only.
Did you try to call a dealer or other part place?
Old 06-29-2011, 04:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
You can buy just the clutch. I wouldn't do it. The clutch often wears out because the compressor is failing and takes more torque to turn it. A new clutch won't last long, either. The best way to fix this is to replace the clutch and compressor.
Old 06-29-2011, 07:22 AM
Ridenred333
thanks for both replies. ya they do sell the clutch by itself but as mark stated I wounder how long it would last.. The clutch is around $80 doing the whole system if i pay someone is about $600 meaing clutch compressor orfice tube and evap seperator thing plus labor.
Old 06-29-2011, 04:58 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
I replaced the clutch and pulley on my old 97 at around 160K. Sold it to my nephew at 200k and the compressor is still going strong.
YMMV, but for my money, replacing the external wear items made a lot of sense (and dollars).
Old 06-29-2011, 10:57 PM
Monster-4's Avatar
Monster-4
Monster-4 is offline
By not working what do you mean? Is it just blowing warm air? Is the clutch engaging properly? If not have you checked the gap between the clutch and pulley surface? You can get a shim kit from a Ford dealer and reduce the gap so the clutch can engage properly.
Old 06-30-2011, 01:33 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
A quick check is to measure the clutch air gap. If it's too wide, the magnetic coil can't get the clutch plate to engage dependably.
So many people were having a problem with this that I did a write-up so that it wouldn't have to be explained over and over.
Take a few minutes and try what you read here:
Compressor Clutch Air Gap
Let us know how it goes.
Pop
Old 06-30-2011, 07:14 AM
Ridenred333
Sorry all i should have said what truck i have also. I have the f250 with the v10. I will check it out spring pop..Ya if blows but is warm air and i dont hear the compressor engaging at all. I will take a look tomorrow or this weekend.
Old 06-30-2011, 08:27 AM
SpringerPop
The V-10's compressors are at the bottom, not the top of the motor, but the idea is the same.
Things are pretty tight and cramped around that compressor, so to get some room to work, you may want to test things, determine how much you need to adjust, then remove the de-gas bottle (coolant recovery tank) to actually remove the clutch plate.
It's not as easy as a diesel 7.3, but the repair is the same.
Pop
Old 06-30-2011, 01:40 PM
tcjhkbjt's Avatar
tcjhkbjt
tcjhkbjt is offline
I have an 04 F250 that I am having problems with my A/C as well. I was reading up on the clutch issue, but when I went to look at mine I did not see a bolt in the center of the clutch. Is there suposed to be one on that year model?
Old 06-30-2011, 03:57 PM
SpringerPop
Yes there is! Got one FAST and install it!
In the meantime, pull your clutch plate off completely. You won't have A/C, but you won't have a metal disk fly off into the degas bottle or fan/radiator! Be sure to save the shim(s) that are there, too, for replacement/modification.
Here's what that bolt looks like:
http://springerpop.net/F350/images/compressor7.jpg
Pop
Old 07-01-2011, 07:06 AM
tcjhkbjt's Avatar
tcjhkbjt
tcjhkbjt is offline
so do you think that would solve my a/c issue? I guess it would draw the clutch closer to the compressor right so that it would inguage? Thanks for your help
Old 07-01-2011, 07:15 AM
tcjhkbjt's Avatar
tcjhkbjt
tcjhkbjt is offline
I noticed in the pictures that this compressor is on top of the motor behind the raditor cap. On my 04 F250 is it on the bottom of the motor?
Old 07-01-2011, 01:29 PM
SpringerPop
That just means you don't have a 7.3, but either a gasser or a 6.0.
You still have an FS-10 compressor.
The physics of the whole thing remain the same. Your room to work may differ.
Have you heeded my note about urgency of getting a bolt in there? DO NOT drive your truck without a bolt in place!!!
Pop
Quick Reply: A/c compressor clutch
