RCS light on when in 4LO only
I have a 2006 Explorer V8 and when I shift into 4LO the RCS light comes on. It is not on in either 4HI or 4AUTO and can be turned off (causing light to come on) if desired. I recently installed the Neutral Tow Switch so that I can tow it behind the RV but I do not know if the RCS light in 4LO was a problem before this NTS was installed or not as I never put it in 4LO that I can remember. Has anyone had this issue or know what the problem could be?
this could be normal, I was once in a jeep liberty for a little bit that would shut off the traction control and stability programs in 4 low. The reasoning being that you would probably need wheels to spin and don't need/want the system intervening. I think the 2011 F-250 I rented did it as well
w74bronco
02-09-2014 12:40 AM
doc_nomad
03-03-2004 10:58 PM
