92 rear axle seal leak
Old 06-24-2011, 08:08 PM
RednecksF150's Avatar
RednecksF150
RednecksF150 is offline
Just found out that my rear axle seals are leaking, was wondering how hard of a project it would be for a rookie to change them out and what exactly I need to do. It's not too bad yet but I'd still like to get it done sooner than later. Thanks.
Old 06-25-2011, 07:33 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
Are you talking out at the tire? The worst part about working on an 8.8 rearend is having to remove the rear cover to remove the axles. Drain the fluid into a pan and remove cover(don't pry hard as if you twist it up it will leak-- been there, had to buy new cover).
Rotate ring/pinion and find the small bolt in the side of the differential(it's like a 3/8" size head). Very carefully loosen it(dont' get crazy, as they can break off). Remove bolt and slide the pin out of the center of the differential. This will allow you to push the axle INWARD to allow the C clip to be dropped off the end of the axle. Do each axle and then slide them out. Replace the seals and reverse the procedure.
You'll need some good silicone for the rear cover and new grease(modifier if it's a Limited slip). It's not a difficult job and with simple hand tools it's doable.
Back in the day with a 9" housing, you just unbolt the axle once the tire/drum is off. You don't have to deal with the differential(draining it and removing a cover).
HeavyE85
10-31-2016 09:54 PM
FordNurseryman
1997 - 2003 F150
07-28-2016 08:34 AM
Sharkster54
04-17-2016 08:58 PM
highboy390fe
1997 - 2003 F150
10-13-2011 09:48 PM
mikefender
04-21-2007 09:16 PM
Quick Reply: 92 rear axle seal leak
