Whats The Best Kind Of Tuner For A 1996 F350?
Thank you guys for all your help. Yes I am replacing the stock down pipe with a 3 inch then from the 3 inch going to a 4 inch straight pipe. I have been looking at gauges but haven't found a decent site, so thank you for a great site! I will look into a DP tuner because more of you guys recommended that one over the others.
That means that if you don't like the tunes you get, or you want to try a different tuner later you can send the chip to one of the others and try their tunes and it will cost less because you already have the chip.
With DP Tuner they use a different style of chip so you are basically stuck with their tunes unless you buy a whole new chip from a different tuner if you want to try something different later on.
I have been looking for a Trans Temp gauge, Boost gauge, and a Pyrometer gauge.
Whats a good site for them?
So you wouldn't recommend going with a DP tuner? What exactly would you recommend me trying first? I heard some tuners are hard on the tranny, and having my tranny go out would put me in a huge hole right now.
I can't say anything bad about DP Tuner, I had their tunes in my 99 and loved them, and Jody was great to work with. I went a different route with this truck (will be going with Tyrant Diesel tunes) because I got a good deal on a blank chip.
TS tunes are okay but not great. All the tuners mentioned in this thread with the exception of DP Tuner can burn tunes onto a TS chip for you though.
I have not been on here a lot either, and have the highest regard for the many people that have helped me, however (the other shoe drops) The guys at Swamps have been great to work with as well.
Ashley you should check the fuel pressure and maybe upgrade the IDM as well. The 120v in my '95 was an improvement-replaced the 100V- which I did after the 3" pipe and 6637. Not having access to a dyno I have done each mod as individual, and watched results. People riding in the 12' bed '95 have been impressed with the budget mods.
Well, she'll probably end up getting a three-pod A-pillar fitting to put the gauges in, so unless she goes for a two-in-one gauge, she'll need to choose three. If she has an auto, then trans temp will be important. I run a 5-speed, so I did get a fuel pressure gauge. I think she'll be good with the ones she has mentioned.
Riffraff Diesel Performance Parts: Ford Powerstroke Gauges | 7.3L Powerstroke Gauges | Diesel Gauges & Accessories - Gauges & Mounts
As mentioned, Clay treats customers well and is a supporter of the forums. Give it a whirl.
Best of luck and ask anything whenever.
Yes, if you can find a really great deal on a used TS chip, buy it and then send it to one of the good tuning guys already listed to get it burned with better tunes.
DP-Tuner has up and down buttons you push to change tunes. The rest of them use the TS style chip with a rotary **** that you turn and can feel click as it goes into each setting.
I'd also suggest you either give us a general area you live in, or check all the tuners mentioned and see if you're lucky enough to live near one. I ALWAYS recommend the local guy if he's on the good list. Having them close by for any re-burns, adjustments, or the option of live tuning is priceless.
I have a tony wildman 4 position chip and love it but lately I'm not too happy. The switch broke a couple months ago and he will not return my calls or emails about it. I've sent SEVERAL. I understand problems and hear he is going through something but unless you can talk to him on the phone I'd hold off ordering from him. I was able to fix my switch thankfully. FWIW, I only use the tow setting and stock setting. They all suck except the stock setting in traffic because the throttle is really touchy but tow setting really will tow! It also gets my best gas mileage. I've gained 5 mpg easy since getting it and that alone keeps me happy with it.
#30
Get a separate EGT gage. That's my opinion.
