Whats The Best Kind Of Tuner For A 1996 F350?
I have a 1996 F350 7.3L with 240,000 miles on it and I want to place a tuner in it for better performance but not trash the truck itself. This is basically a daily driver but also a farm truck where I pull trailers and whatnot. I want the truck to have better towing, power, mpg, and etc. I have been looking at several different truck tuners but I am not the most experienced with tuners. What would you guys recommend for my year and purpose?
Thanks, Ashley |
A six position chip from any of the following.
Swamps Beans Gearhead Performance Total Diesel Performance( Tony Wildman ) Power Hungry Performance Just to name a few. All these companys use the same chip and can reburn them. Get a hold of each tuner and talk to them about what you want. I will say Gearhead has great customer service. |
Dp-Tuner and Tyrant Diesel are a couple of more.
I have heard many good things about those as well! The DP one I have heard often!
I have DP-Tuner in mine and am happy.
I love mine from Power Hungry Performance.
Just keep in mind that you won't be gaining much from the chip without a better intake (6637 from RiffRaff Diesel is good) and a bigger downpipe (3"). It is also highly reccommended that you install gauges to keep an eye on your Exhaust Gas temps, Transmission Temps, and Boost |
Welcome to FTE Ashley. While you've seen many suggestions here, you'll notice the ones who advertise in all those magazines are not mentioned. There's a good reason for that. The custom chips with switch on the fly capability are MUCH better than anything you can buy off the shelf at a local store. The custom chips aren't really much more expensive, but offer much better benefits.
If you're going to be using the truck for towing or playing, you really need to install a set of gauges so you can monitor a couple of things to help protect the motor. Auto or Stick? For an auto you should add a temp gauge, and maybe a shift kit and auxillary cooler. |
Ease of use, I always recommend DP tuner.
I'd stay away from beans or swamps. Just my .02 on that though. |
Originally Posted by pjwoolw
(Post 10490582)
Originally Posted by Talyn
(Post 10492404)
I'd stay away from beans or swamps. Just my .02 on that though. To the OP, any of the above Tuners will do great. Like one person said, call all them and talk to them and go from there. GOod luck with your decision |
Ken, seeing as you don't visit our site here that much, You'd not understand that lots of people on here have problems with swamps and beans.
I don't have to explain myself on that. Jeff was just pretty much naming everyone off. |
(Post 10493481)
I don't have to explain myself on that. Jeff was just pretty much naming everyone off. Anyway, what i highlighted is what im talkming about. maybe explain some of those problems as to why u dont recommend them. just makes things a little easier. I have been around these forums a long time, i know all about all of the tuners out there, the pros and cons to all of them. Dont act like i have not a clue about any of them |
Welcome Ashley! :-X25
Definately the TS 6 position chip and any of the custom tuners they previously mentioned are good. My friends and I have experience with Tony Wildman and he does good tunes, but he has some stuff going on so his service takes longer.. Wont elaborate more. What I would recommend to get the best performance out of your chip is like they recommend. If it is BONE STOCK then you should get a larger DownPipe for your exhaust installed(I would straight pipe too to get rid of the kitty). I would then recommend getting gauges too like f350-6 said so you dont burn up the inside parts of the motor. Trans temp, pyro, and boost are good if you have an Auto. I like this package at glowshift. close to $200 for everything you need...they change colors and bunch of cool stuff to match your dash or whatever. 92-97 Ford F-Series Truck Custom Diesel Gauges Package Those two add-ons with your chip will make it perform great. IMHO. :-drink Oh and Ken and Keith.. you make a song pop into my head.. "Why cant weee be friends. Why cant weee be friends." :-X14 :-duel1 |
Talyn I'm curious how a rotary knob is any harder to use than an Ex switcher from DP? I don't smell what you're stepping in there.
Originally Posted by CountryGirl3294
(Post 10490508)
Thanks, Ashley I think almost every thing has been exposed above about the tuners so you can make a decision. I have the TW chip (Tony Wildman) and Im happy with it. :-drink ps: DONT hear thouse fights between members here, are very rare. :-X19 |
Thank you guys for all your help. Yes I am replacing the stock down pipe with a 3 inch then from the 3 inch going to a 4 inch straight pipe. I have been looking at gauges but haven't found a decent site, so thank you for a great site! I will look into a DP tuner because more of you guys recommended that one over the others.
