back axle
back axle
Hi guys hope you can help me. when i bought my truck (ford f1 1949) the rear springs were shot so i had them re tempered but now it sits too high i just wondered if there is a way i can sit the axle on top of the springs instead of underneath although there is a braket on the top of the axle to take the curve out and for the u bolts to fix to? hope you understand that sure you will cheers Dave.
Thanks Vern but my question is still the same can it be done and if so how?
on
I put the axle over the springs in my truck but I did not use stock springs. This is a picture of my truck using 87 Chrysler rear springs. I made my own brackets to mount them. I can't say how your truck will come out using the stock springs but I would guess something similar. I did not C-notch the frame and have 3-4 inches of travel in the rear suspension.....
Sacramento Vintage Ford has a 'FLIPPED REAR AXLE KIT 1948-56' (P/N 07379) for$130. The kit gives you all the parts you need to do it but the new spring pads have to be welded to the axle.
Good luck
<CENTER>
07379
Mounts any 3 inch diameter axle housing on top of your 2 inch wide springs. 1948-56. Additional shipping charge $7.50. Page 306 2012PT 14:05:52 24 JAN 2007BEATRIZ</CENTER>
Good luck
<CENTER>
07379
Good luck
<CENTER>
07379
Good luck
<CENTER>
07379
Dandy_Dave
32
04-27-2013 12:23 AM
smashclash
11-28-2010 12:37 PM
