Anyone need this front axle. 67-72 F-350 4X4
I hate to scrap this front axle. I was hoping someone on here could use it. It is out of a one ton truck that a buddy of mine scraped about 10 years ago and I saved the axle because it was good. Looks like a 4.09 ratio. The numbers on the gears are, 10-4-67 DANA 18520 M8R84 45-11 The rear would most likely have been 4.10's as the front axle must pull a little faster. It is a DANA 44 and is the early closed ball and drum type with Warn locking hubs. Still has the front springs, a piece of the frame, and steering box attached. It is located in Craryville NY. I have a backhoe and can load it. My number is (518) 325-7610, Ask for Dave. Just make an offer. Thanks.
Well maybe you and I will find out. I know when I was a kid not many trucks had 4 Wheel Drive. Even in the 60's it was not common even up here were it snows, especialy for a one ton. It seems a lot of them get changed to the newer open knuckles and disk brake type. With that said, I thought if someone was restoring a truck to original condition for show,( AACA or similar rules.) that needed an axle, I would give them an opportunity to have this one, rather than just run it to the junk yard. Dandy Dave!
It may well be a Dana 60. It has much larger enclosed type knucles than the DANA 44 front end in my 1962 F-250. No numbers stamped on the long tube. The axle is most likely around a 1967 or 1968 by the date on the gears. I don't see much info on the web for these early DANA axles. Just the later ones. Although the pumkin does have 44 cast in it, so I assumed it was a 44.
Hang on and I'll post more photos for the experts to chew on.
I have a 1974 W-300 Dodge that I tow my trailer with from time to time. That has the military dogbones, instead of universals where the enclosed Knuckles are. I believe it is a DANA 60 under that truck. Thanks, Dandy Dave!
1967/72 F350 4X4
I hate to scrap this front axle. I was hoping someone on here could use it. It is out of a one ton truck that a buddy of mine scraped about 10 years ago and I saved the axle because it was good. Looks like a 4.09 ratio. The numbers on the gears are, 10-4-1967 DANA 18520 M8R84 45-11 The rear would most likely have been 4.10's as the front axle must pull a little faster.
Dana 44 front driving axle w/8 lug wheels: It's from an F250 / 10-4-1967 = October 4, 1967, so it was originally installed in a 1968 F250 "High Boy."
There have been people looking for parts from that type axle, but I haven't seen a request in about a year. I had one, scrapped it. Light duty axle and not worth repairing IMO. I've replaced them with either the later D44HD open knuckle, or a D60 in one case.
The real weak point is that enclosed knuckle- They leak like crazy, and if you break a u-joint, the pieces all stay in there and beat the axle shafts apart.
I would pull the shafts out and scrap the rest. The gears are some of the most common gears ever made too.
