ball joints time
on
ball joints time
I think I am going to need to replace my ball joints in the near future and saved a link that someone on fte posted on XRF ball joints. XRF Chassis | Automotive and Heavy Duty Chassis Parts | Canada and Unites States
I was wondering if any one has had any experience with them, or heard anything about them. It is either these or the standard moog, which are only slightly cheaper.
wallz,
Do not know about the XRF, but did find out the Moog's were not a good replacement on my EX. They were so tight when installed that it took a gorilla to manually rotate the knuckle before the linkage was re-installed. I had the tech remove them and replace with Ford joints (which by the way also have grease fittings now) and all has been great.
That along with an alignment fixed my wander/return-to-center issues.
We carry the Motorcraft one's. Here's a link to them if you would like to check them out.
Ford Excursion Ball Joints
We carry their products,if anyone has any questions on anything,shoot me a PM and I can answer them for yah.
The Mechanic who did my Excursion told me the front end is so heavy he can understand why the ball joints go bad at 100K... if you have a 2WD I would have a shop put it on a lift and check it out, especially if you have 100K or more.
on
Thanks guys for your responses. I havent decided yet on what to get. I will need to replace before the summer is over tho. Probably going to go with the XRF. If I do I will post back on what I find. I will be doing this on my own unless something happens. Still havfta order in the rest of the seals to, so it will be late summer at best.
Did mine four month ago. Just make sure they have grease zerks and put them on before you press them in. You may never be able to get grease to them if they end up pointing the wrong way. Also found that the second side generally take a third of the time as the first side you do. Good luck and 3/4 drive wrenches will help.
