bed length
I think he's referring to a chassis cab. Should be a 165" wheel base, 84" cab-to-axle. That's just a touch over 11' of frame, the fuel tank is likely behind the axle, I would suspect a pickup bed is going to be out of the question unless a guy has 2 donor beds and some awesome body work skills. As for a flatbed, most upfitters will spec a 12' bed for an 84"CA, but you could get away with something about 11', but I'm not sure who makes one that length.
I'd have to measure mine (I have the same WB/CA truck as you're referring to), but as I recall, it was just over 11' to the end of the frame rails. Many flatbeds for your truck are going to be 12' and have a crashbar/rear skirt that hang past the end of the frame rail. Also, if it has a frame mounted trailer hitch, that's going to stick out past the end of the frame rails a bit as well.
woodsmoke
07-22-2010 09:53 PM
Tim M
10-24-1999 07:34 PM
