tank selector/fuel return ?s on a 94
Cut from my Ford Service Manual:
The following provides a brief description and function of each of the FDM internal components.
The high pressure fuel pump is located inside the module.
The shuttle selector valve opens the return line to the tank and the return flow is directed to the appropriate tank on vehicles equipped with dual tanks.
The supply check valve, which is normally closed, opens when the outlet pressure from the energized pump exceeds the opposing check valve spring force. When the pump is de-energized (i.e., engine is shut off), the supply check valve closes to maintain pump prime and fuel supply line pressure.
A portion of the high pressure flow from the pump is diverted to operate the venturi jet pump. The venturi pump draws fuel from the tank into the fuel delivery module reservoir to augment the engine return flow. This process ensures an adequate fuel supply to the pump during extreme vehicle maneuvers and steep vehicle attitudes with low-tank fill levels.
The inlet of the venturi pump has a nylon filter on it to prevent dirt and other particulate matter from entering the system. Water in the fuel tank can pass through the filter without restriction.
Welllllll, I did a carb swap, so on order to get low enough consistant pressure I had to drill a hole Here
I only did this to one tank, so right now the rear returns to the front tank along with the front. , if I do this mod to the rear tank, I think I will need to adapt shut off valves to the return lines at the tanks to keep the fuel returning to the proper tank, am I thinking right on this?
cdat81986
19
07-22-2022 05:54 PM
Paul E.
07-21-2010 09:08 PM
coolhand1994
03-27-2009 08:16 PM
bluesman2333
13
02-03-2008 08:15 AM
