"65 Cab Repair - Swiss Cheese version!
Hey all. Been awhile since Ive posted any work. Ive been working away at the old girl, but Ive been a little limited on time. Finally got some real work done today though. I will let a few of the pics speak for themselves.
You can see the floor is in pretty rough shape.
3500 PSI power washer with a sand tip on it. Works well, and safer than a sandblaster. Doesnt get down to bare metal as fast as a sandblaster though.
You can see the full extent of the floor damage here.
Some cutting work started here. I just cut what I have to. Can always cut out more if need be.
Cab support mounting area cut out and ready for new steel.
New steel in place for cab support.
Clamped and prepped for welding.
New cab support in place.
Last pic is a shot of the lower door pillar removed. I left about 1/4" extra metal in place so I can cut a little more to make everything fit.
As you can see, I have my work cut out for me. I have to sandblast again to get things cleaned up enough actually work on it. I have to fab alot of metal. I have a bunch of welding to do. In other words, I have a crap load of work to do...
I posted all the pics on my Facebook page here with comments: http://www.facebook.com/media/set/?s...3&l=c7ac4bc01c
My Picasa/Google web album has every pic Ive taken since I started here: https://picasaweb.google.com/1081911...0196/FailTruck
I hear that hooch when I see what the tin worms do to stuff back there. I just got a bumper off a 66 custome cab out a pull and save he would probably crap if he saw what kind of shape that cab is in. Hooch we got to get together and figure out a way to make some money getting cabs front clips and stuff from out here to back there.
Blasted the bad rust off today. Forgot my camera today because I was a little rushed. Ill get some pics up next weekend.
Other than the obvious, a real hurdle here is getting the lower inner door mounts in exactly the right spot when I rebuild the panel both up and down and in and out.
I thought I could possibly layer up some steel and use a piece of 16g as a place I can mount the hinge to. I also will need to go pull the lower hinges out of the doors and use them as a pattern to get the nuts in the right spot. Anyone have any ideas beyond that?
Buzz44, jhooch: Im in the market for a set of inner fenders and a battery box from a 65/66 if you know of any... I thought about trying to get some outer fenders from a donor, but after talking with my body guy he suggested just ordering repro's as in the end it will cost me more up front, but less body work, so it all will be about the same cost by the time the paint is on.
looks like you could use replacment section's.
i have both sides (from an AZ truck) already cut out and you can HAVE them if you want.
Thanks guys. I am always up for a challenge. And this definitely is one.
I hope to have the frame coated, and the body done by winter. Depending on what BillW has laying around, it could potentially cut at least 20 hours of fab work off this rebuild and be correct, instead of me playing a guessing game trying to piece stuff back together.
