new 7.3 owner here
Old 08-26-2013, 12:37 PM
95f3507.3's Avatar
95f3507.3
95f3507.3 is offline
new 7.3 owner here
Hi there folks, first post here, I live up in northern alberta Canada. I just recently purchased a 95 F350 with the 7.3, 5 speed manual tranny, 179000 km's. Has some issues, when a rev it up in neutral it smokes and sputters approx 2000- 2500 rpm...low end power seems ok, starts ok too as long as I glow plug. It when cold.
I've read A LOT of uesfull info on here already,but I figured I would ask the experts before starting to trouble shoot.
BTW fuel filter is changed.
Thanks
Old 08-26-2013, 01:01 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
Welcome to FTE!
Couple of questions:
Does it do this when your driving it or just when your sitting there in neutral?
Does it have a chip or programmer?
If you get a chance post up some pics! You will have to upload them to photobucket or flikr and link them back here, we all love pics around here!
Once again welcome to FTE!
Old 08-26-2013, 01:20 PM
95f3507.3's Avatar
95f3507.3
its most noticble when in neutral, but it seems to lack top end power when driving.
will post pics when i get the chance, its a red dually flat deck with strait pipes. really like the truck already even though its not workin right yet.
Old 08-26-2013, 01:28 PM
madMatador78
Well the reason I ask if there is a chip is because there is a power limiter that prevents the engine from going above a certain RPM that is built right in to the PCM.
Old 08-26-2013, 01:36 PM
95f3507.3's Avatar
95f3507.3
i have NO idea if its chipped or not. (bought at auction) fastest way to find out? if i floor it long enough it smoothes out after a bit.
Old 08-26-2013, 02:42 PM
DarkStarMedia's Avatar
DarkStarMedia
DarkStarMedia is offline
I would check your fuel pressure (tire gauge at the valve on the fuel bowl) and then maybe look at the CPS...
richard
Old 08-26-2013, 02:48 PM
95f3507.3's Avatar
95f3507.3
Ok, sounds simple enough. CPS...? Don't know the lingo yet!
Old 08-26-2013, 02:54 PM
DarkStarMedia
Crank position sensor. Always carry a ford/IH one in your glovebox along with a 10mm socket and ratchet.
Riffraff Diesel: Motorcraft CPS 94.5-03
I have never had to change one but this is one of the first things to try when the engine starts having issues.
The PSD is pretty simple as far as common rail diesels go. Not a lot will stop them but the CPS is one of those things. It is apparently very easy to change... As I said i have never had to though.
Richard
EDT: I figure check the fuel pressure first cause it's a cheap and easy check.
Old 08-26-2013, 03:14 PM
95f3507.3's Avatar
95f3507.3
Thks, lots of good feedback already! I will pick one up today, sounds like I want a spare one anyway.
Old 08-26-2013, 03:16 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Thanks
Sounds like it could be injector o-rings.
Old 08-26-2013, 03:57 PM
tshrager's Avatar
tshrager
tshrager is offline
That's what I was thinking. IIRC, there's a crude neutral test to tell. In neutral with the engine warm, rev it slowly to 3k. See if it stumbles around 2700-2800. I think my numbers are right. Lol
Old 08-26-2013, 04:00 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
I think it's usually around 1800-2200 rpms, but I'm sure that can vary. Pull the cap off the fuel bowl and see if the fuel in the bowl and the filter itself is real black looking.
Old 08-26-2013, 04:54 PM
95f3507.3's Avatar
95f3507.3
lots of good advice on here, makes it alot easier for the do it your self mech
i will post updates when she's running strong!
Old 08-26-2013, 06:06 PM
madpogue's Avatar
madpogue
madpogue is offline
CPS is the CAM position sensor (there is no crank position sensor). As said, required glove box content.
Chip check - remove the fasteners for the parking brake handle assembly (leave the cable attached) and move the assembly toward the right side of the truck, away from the cab wall. You'll see the PCM sticking into the firewall from there. The chip will be plugged into a socket in an opening in the aft end of the PCM, if one is there.
Old 08-26-2013, 08:01 PM
fordman67's Avatar
fordman67
fordman67 is offline
I was thinking 2200-2500 generally speaking iirc. how black was that old fuel filter anyway?
Quick Reply: new 7.3 owner here
