need vacuum help asap
the picture below is confusing me a bit. the bottom part goes into the cab to the air conditioning stuff, and the top part goes into the vacuum tree. what does the left part go into? im re running all my lines simpler than the way they came from the factory following a write up on fullsizebronco.com.
also is that conector just a tee? or is it a special one way valve or something?
i need to know how to run these last few lines to finish up my truck.
Some good info and pics in this thread from another forum: A/C and/or heater stuck on defrost - FSB Forums
well im pretty sure i foudn my problem. i found a vacuum door or actuator. whatever their called under the dash next to the glove box. i turned on my ac and pushed it in and it started blowing out my vents like its supposed to. so im assuming its that blue line that goes to it or could it be that thing itself? anyways the line goes upbehind the dash and im having a bit of trouble tracing its path. i know it eventually plugs into the a/c control panel but before that im not too sure. am i going to have to pull part of the dash off for this one?
I have never hear of that blue vacuum line or its Panel Door vacuum motor going bad.
As said above most of the time it is the white vacuum line going to the vacuum motor on top of the heater/AC box that has a break.
But your truck from what I can gather is not getting any vacuum to the vacuum control on the dash. photos and images above in this thread.
No vacuum to selector vacuum valve (vent system).
