what wood u have to do change the yokes,transfer case?
It's not that simple.. there are wiring differences. This is all just speculation until you find out exactly what transmission is in each vehicle, there were a total of 4 different automatics available for these trucks so you need to know what you got, start by finding the trans code on the drivers door pillar of each truck and post it up.
I took out a 94 e4od from a bronco and put it in my 90 f 250 with the same trans no problem only thing other that needed to be Swapers out is neutral safety switch
