My brother has a 95 f250 powerstroke with an a/c issue. It is darn cold when it works but for some reason the clutch wont kick in unless to hit the clutch wheel part. I can unplug the sensor on it and it will stop but when i plug it back in i can hear it bog down like it is trying to kick in but wont untill you hit the clutch wheel again. Is there a kit to rebuild this or do you just replace the whole compresor?
Sorry to hijack this thread but my late 94 that i just bought, i cant get the clutch to even try and kick in.
Could be low on freon that would make it not kick in. I think you can jump across a sensor plug in to see if it kicks in but someone else better say which one.
I forgot what the gap your supposed to set is, but good rule to follow is make sure its not dragging while the motor is running, and if you apply voltage to the connector at the top inside, it will suck in the clutch.
That way you can tell if its making good contact or not.
They generally just wear and need to be re-shimmed.
Ok i will give some of those a try, I knew that the a/c didnt work right if the pressure was low, but my experince is that it trys, but kicks right back off
