Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
04 Escape Turning Vibration
Old 06-10-2011, 10:25 PM
bintopo's Avatar
bintopo
bintopo is offline
Hi,
I have a vibration when turning to the right coming from the front. Seems to be getting worse over time. Any ideas or suggestions?
Thanks
Brian
Old 06-11-2011, 06:11 AM
tomw's Avatar
tomw
tomw is offline
Loose steering linkage, worn bushings, worn constant velocity joints, bad tie rod ends, loose bearings, bent wheel, worn ball joint, loose pinch bolt could all cause or allow vibration.
Please tell when the vibration occurs, such as cornering in town, or on the highway at speed, or turning out of a parking lot.
tom
Old 06-11-2011, 11:44 AM
bintopo's Avatar
bintopo
bintopo is offline
Just did a test drive. I start to feel a smaller/slower vibration around 40km when turning to the right while rocking the steering back and forth. It starts to really hum around 70km plus when rocking back and forth.
Thanks
Brian
Old 06-12-2011, 08:26 AM
tomw's Avatar
tomw
tomw is offline
I gather it is not shaking the steering wheel, just making a humming. When you have noise that comes and goes by turning the steering wheel back and forth, you are unloading and loading either side of the tires more than in straight ahead driving. I would inspect the wheel bearings as I think one of them is going out.
tom
Old 06-12-2011, 09:25 AM
bintopo's Avatar
bintopo
bintopo is offline
Tom,
That's what I was thinking. Now comes the fun part.
Thanks
Brian
roholendt
1997 - 2003 F150
06-02-2016 05:26 PM
Supercrewzin01
2004 - 2008 F150
12-28-2014 08:07 AM
bkvanbek
11-26-2013 06:05 PM
Mazellan819
05-07-2012 12:21 AM
CrazyMiracleMan
1983 - 2012 Ranger & B-Series
19
12-15-2011 11:30 PM
Quick Reply: 04 Escape Turning Vibration
