Batterys or Alternator?
In the last two weeks it's gotten slower and slower cranking to start. If I try to start it four hours after shutting down it starts just fine, cranks full speed, etc. If I try to start it after sitting for 8 hours or overnight it cranks slow, and its getting worse and worse by the day.
Would batterys fail/deteriorate this quickly?
on
I recently changed both my battieries due to one failing. I had no starting issues until I had let my truck sit for a few days while out of town. Come Monday morning when I left for work, it would not start. Had to charge the batteries for 1/2 hr and use the charger's "boost" to get'r going. I tested the batteries, and charging system, (alternator-OK) after charging them for a few hours that night and found a 4 bad cells in the driver's side battery. The passenger side had been weeping acid around the top, so both were in need of replacement. Now, all is well again.
In short, "YES" you could have bad batteries. I would have them and the alternator tested.
There should be a date code stamped (or heat-branded) into them somewhere so you CAN tell their age. After about three years, or a few accidental discharges, the batteries are a real suspect.
It sounds like the reserve capacity has diminished to the EOL (End of Life) point. Eventually the sulphation process takes its toll on all lead-acid batteries. New ones will most likely solve your problem,
However, if the alternator has over about 120,000 miles on it, it might-well be "gone through" by a competent local rebuilding service when you've got a couple of down days.
That's NOT the same as swapping it out at the parts house!
A healthy vehicle electrical system isn't accidental.
Pop
Pop
Powerstrokin250
02-16-2019 02:15 AM
Freaksh0w
25
08-28-2010 04:35 AM
Nillabean
02-08-2004 07:52 PM
