map sensor
black wire i have 1.4ohms
so basically my tps is good right?
Have to say no, however not real clear how you tested it yet. You did disconnect the TPS harness connector, tested sensor resistance with it off correct?
The manual I have shows em as,
Brn-Wht = vref
Gry-wht = tp
Gry-red = sig-rtn
i installed it correct with setting it on and rotating till the screw holes line up and tighten them.
To adjust (91 and up) loosen screws, connect negative probe to the terminal with the gray/red wire and the positive probe to the terminal with the grey/white wire. rotate sensor with the ignition key "on" until the output reads 1.0 volt. Tighten screws recheck voltage.
Sounds like your in the ball park far as that goes though has .09-4.21v with a steady increase to wot and decrease to closed position. your within spec there.
orange wire has 5.05v be just a hair high, that .05v very small amount yea and might just be a slight error in your meters readout at that voltage range?
Brn-Wht = vref
Gry-wht = tp
Gry-red = sig-rtn
[QUOTE=timbersteel;10443065]I would do a resistance check from the PCM harness to the TPS connector. how do i check this?
yes i had the battery disconnected over night.
i just back probed the connector while the tps was hooked up should i unhook it and re-test it?
not shure on the idle screw.
one minute it will idle fine with no cel and the next it wont idle and the cel is on and while driving down the road it seems like the throttle is dead with the pedel depressed 1% to 20% down and then it will jump and go good till i let off the throtle. so i think it is something to do with the tps. and the only code i get out of the ordinary is 122, i get tranny codes but that is because the po put a 5-speed in a automatic truck. any help is greatley aperciated
An adjustment of the TPS should/might be enough to correct for it.
Most of the TPS sensors for these trucks I have seen have very little to no adjustment. I wonder if a previous owner has jacked with the Idle Stop Screw? If you disconnect the IAC does the truck die? It should drop the idle down to the 400-550 RPM range IIRC. Moving that screw will negatively affect the TPS output voltage.
Yea me either, only the little slop in the screws would allow for. No actual adjustment "slots" built in allowing one to be rotated couple degrees.
how do i adjust it correctly?
I posted it up in #16 you must have missed it. Book states,
To adjust (91 and up) loosen tps screws, connect negative probe to the terminal with the gray/red wire and the positive probe to the terminal with the grey/white wire. rotate sensor with the ignition key "on" until the output reads 1.0 volt. Tighten screws recheck voltage.
You might get enough to make the difference even though as with rla2005 and I never seen any amount of intended / built in adjustment in the TPS, least not for the model year.
If the throttle plates are not digging into the throttle body when fully closed you might better elongate the mounting holes in the tps a tad if needed, rather then mess with that stop screw. Simply drilling the tps mount holes out couple sizes larger would add in some degree of adjustment to it.
there was enough light out yet to do a little more work to my truck so here is what i found.
i let the truck warm up and pulled the iac wires off and there was no change in idle.
i have a 351 and would have to pull the throttle body off to do that. is it possible to adjust the tps with the throttle body off the truck.
I am a little confused here with the statement in bold above. Is the TPS output .9 or .09 VDC with the throttle closed?
#28
#29
Whats the idle speed?
Any yes you can test/adjust the TPS with the throttle body removed, wouldn't effect reading/setting. And yea no real way to do it with it in place!
black wire-1.4ohms
You continue to post that value but its pretty much meaningless without knowing what the black wire connects to and how your taking that reading.
To test the TPS resistance you must remove the harness connector and test the TPS itself, not done by back probing at the connector.
Are you using a analog or digital meter? analog is the best choice for testing TPS. Digital meter will likely not react quickly enough and or smooth over any "blips", masking any bad spots it may have you'd want to see during the testing.
#30
