1996 F150 Jerking/Stuttering
My 1996 XLT, rear wheel drive, straight six, 300 fuel injected engine, seems to jerk or sort of stutter when it I think it maybe should be down shifting when driving. It shifts up just fine and then down when it reaches a shift point. Using the "overdrive off" button on the shift works fine and I'm wondering if I really have a transmission, a fuel flow or an ignition problem. If I press on the accelerator to pickup speed it will "jerk" a few times and then smooth out. It doesn't matter if it's cold, hot, wet or dry. I still get the same symptoms even if I use the front or the rear fuel tank. Other than this annoying quirk it runs fine. Any ideas out there? Thanks...
Checked hoses, no problems. Pulled the sparkplugs and found that all had worn to a gap of over a sixteenth of an inch. Don't know how it was running like that. Changed plugs, wires, distributor cap and rotor. Runs like a sewing machine now. "No jerks, no stalls when up to speed. A little bit of help was all I need". Apologies to Cheech and Chong on that one. Thanks for the information.
moosey78
02-12-2016 03:38 PM
naps1saps
09-12-2012 01:16 PM
