Intercooler & Stage 1s
I did a tow to central Oregon last month on my Stage 1's. No intercooler. I stared at the pyro most of the way. No problems at all really. The engine will keep making power, but you'll hafta remove your foot before you cook things.
I did find I could hold gears longer and farther, but still ended up in third for the larger/steeper grades. Switching to the "Heavy Tow" setting seemed to keep the temps down.
Got most of the parts, but still need a coupla things for my I/C install. Time mostly...
For pipes, you can make up your own or mod some 7.3 Superdooty pipes...
on
Another option no one mentions is using a water injection like the snow performance kits. I don't have experience with them but read an article where it sounds like would have a tripple benefit of cooler intake charge, increased fuel mileage and less fabrication for installation, or need less room to install. Down side is it would be a larger upfront cost.
Intercooler first, If for whatever reason you are still having heat issues, water/meth is a good choice...
I tried towing without an IC and it sucked. All kinds of new power and no way to use it. That said, everyone's idea of what is a heavy load, what's a steep or long hill, how fast you need to go, etc. are different. I'd say go try it and see how you do. Worst case you end up slowing down, shifting down, and turning down your chip till you're close to or at stock power again. You'll get there, you just won't do it nearly as fast.
The issue here is finding a place to constantly be carrying water. It needs to always have some in it. And an intercooler does it's job all the time, slap it on and go...
I told you
