tire sizes
06-03-2011, 05:59 PM
on
tire sizes
will 305/55-20 tires fit on my ford f-150 4x4 with a 2 inch leveling kit
06-04-2011, 08:26 AM
They should. Are you on stock 20" wheels, or an aftermarket set? Stock should be fine, you might get a tiny bit of rub at full lock.
06-05-2011, 03:07 PM
on
yea i still have the stock 20 inch wheels
06-06-2011, 05:36 AM
Make sure you get your PCM reprogrammed for the correct tire size (or your odometer and speedometer will be off).
Please note even if properly programmed, your speedometer will always read 2-3% FAST (i.e., will read about 67 when you're really travelling 65).
06-06-2011, 09:48 PM
on
i have a super chip chip which i can do that with
06-07-2011, 04:35 AM
Good deal. Make sure you account for squish.
Your unloaded diameter should be about 33.2" (843.5 mm), 2650 cm circumference or 607 revs/mile. With a 3% squish (most tires are between 3-5%), you should be about 2446 cm or 626 revs/mile.
Always verify with a GPS or known distance.
bkuuz1
11-13-2010 10:14 AM
johngfla
2004 - 2008 F150
02-13-2008 07:18 AM
guitar4him
1997-2006 Expedition & Navigator
01-03-2003 09:20 AM
brown 4x4
03-19-2002 04:29 PM
