What do you wish Ford would have done to the Bronco before ending production?
#32
Lol, I take offense to that.
I agree though, the 300 is one awesome motor. And Ford actually WAS doing something with it. A guy over on FordSix.com who used to be a Ford engineer actually has an original cross-flow head designed by Ford that he has on his drag racer. I believe it even had SHO embossed on the side.
They sadly scrapped the project.
But yes, the 300 is definitely something they should have done more with, especially in the Bronco. Broncos, although many use them for them, aren't designed to pull and tow big loads. That's what trucks are for. They're meant for the outdoor/off-road enthusiast. This type of vehicle (at least in my use) requires traveling long distances to get to my off-roading destinations, and then when it does, it needs good old low end torque for those mountain trails. The 300 is perfect for this.
Ford definitely should have really honed in on this engine, created a high output version that balanced power and decent fuel economy, and put it in the Bronco. If I can get 180hp/300tq out of my carb'd 300 and still get 15 - 18mpg, Ford could have definitely done much better with a factory redesigned fuel injected version.
#33
#34
Sadly, it's the 250 that got the crossflow head, not the 240. Completely different engines and 100% incompatible.
#36
Broncos can tow. Tow my tractor and my truck as you have may seen
I mean put some weight on the front and put some thicker leaf springs on the back and get a good manual transmission and it can pull anything. ALSO get good brakes.
They can tow, you just have to figure out how to make it where it won't be all over the road when towing heavy stuff.
A pick up is only a little longer than a Bronco but not much.
#37
Just like an extended cab extended bed truck can off-road. It can do it, and probably do it moderately well, but that's not what it was made for, and you usually don't go out and buy one with that thought in mind.
It's probably why they never put the huge V8s / diesels in the Broncos. Those are usually towing/pulling motors.
#38
Oh they can definitely tow. My point is, they weren't designed with towing in mind. It wasn't their goal, or their market.
#42
Might as well go fibreglass with the gate then. And yes they are available. It eliminates the need for the torsion bar inside to assist with lifting to close it. And anyone who has had a tailgate rust enough to release a torsion bar and shatter a back glass knows what a great idea that is.
#43
#45
Strong overdrive transmission = ZF S5-42. Any unit found originally behind a 300(4.9) will fit behind a 302 or 351W. Not to mention they have identical physical dimensions to an M5OD (Mazda-built) standard 5-speed that was available in the Bronco in stock form. It even uses the same clutch setup as the M5OD.
