Backup Camera - Hard Wired
EXCELLENT!!!!
We just had a nav/dvd headunit installed it was set up for rear camera already. We just had to purchase the camera. We got a nice lic plate camera. Unit was like 200 (i think). If we hadnt got the headunit we would have done exactly what u posted.
Urs looks great and pic quality looks just as good for 1/4 the price. Nice!!!!
What I found that makes it easier is to use about a foot of the irrigation drip line - that small diameter stuff you use to run drip lines for flowers. It's stiff and you can run a small wire inside of it. I ran a 'fish' wire through that, then ran that tube through the rubber tube. It's stiff enough to get past the accordion folds in the tubing and you can twist it to make the curves you need.
After you run that through, keep hold of the fish wire and pull the tubing out. Tie the wires you want to pull through to the fish wire, and pull. Took me maybe 2 minutes from the time I found the tubing in the garage to having the wire pulled through and the rubber tube re-installed. I used this on the door boots on my Expedition as well...a little tricker having to do it with one hand inside the door, but still easier than wrestling with a wire fish or doing it with just the wire alone.
Excellent write up, I've been wanting to do this for a while. I also want a camera on the back of my 31' TT, hate not knowing what's behind me.
How strong is that suction cup? I've never had good luck with them. I suppose I could buy two of those kits and add an extended coaxial cable for the trailer.
Oh yeah, any particular reason you chose that camera and not the license plate camera? I'd rather not drill into the trim.
I have been trying to find a backup camera that was wireles so I could move it from the Ex to the back of the 25' Travel trailer.The promlem has been to find one that transmits that far reliably. With this as cheap as it is I could buy 2 cameras and wire them both in place. Hook up the TT camera when I hook up the rest of the trailer connections. Then use a 2 position switch, and just change what is displayed in when I'm towing. Thanks for the great write up!!
I'm doing the same on our SAR trailers. I think I'm just going to use a wired camera and add the 4 pin standard trailer wiring as the hookup. I haven't found any yet that you can get reliable performance on (based on user reviews).
Very nice job! Reps to you!
Now you didn't go find a Prius to park in front of just for the picture, did you?
I used one of those cheap license plate ones for about six months. The screen mounted on a stand that velcro'd to the dash, and I couldn't stand it there. Between that and the fact that the little bubble plastic lens cover on the camera scratched up quite early on, it wasn't worth keeping on. I thought about putting it on the back of the TT though if I could run the wire somehow and had somewhere to put it, but I never have yet.
I just posted a similar comment on a post about having a wireless camera on the rear of my 16ft enclosed trailer (above barn doors). I just browsed over a few comments here, seen kinda what was being said and thought I'd add my information. Hope it helps!
It is the peak wireless with the 3.5 inch monitor. I have great signal with it, even driving down the highway. It has a clear picture and for the price couldn't pass it up! I've had it installed over six months now. I also installed a xav-62bt Sony in the dash with a license cam that I can see the ball and behind the truck with no prob.
When I installed the trailer camera, the wireless transmitter only came about a quarter of the way to the front of the trailer, so i took a telephone wire and spliced in the extra wire to get the transmitter to the front top of the enclosed (where the running lights are). Was a very simple job and the peak only has four wires between the camera and transmitter. I hardwired the cigarette plug to the monitor in the overhead console 12v switched (tested with the key and test light) and stuck it up above the rear view mirror, to the left, so I could see the full monitor and not be covered by the sun visor.
I mentioned in the other post that I didn't know how to post pictures to a post, but if someone could explain how to, I'd do my best to get the on here for you guys!
ReBilld
51
07-14-2012 06:39 PM
77 Supercab
08-10-2011 08:46 PM
