Wheel well liners
Old 09-02-2011, 01:58 PM
Fishhawk460's Avatar
Fishhawk460
Fishhawk460 is offline
Just installed the inner liners. Nice tight fit. They have a factory look to them. Easy install without any drilling. The only thing I had to do was take off my splash guards before I slid in the liners, then reinstalled them.
Props to Rugged Liner!
Old 09-02-2011, 04:39 PM
propellerhead's Avatar
propellerhead
propellerhead is offline
The local shop wanted $199. Still waiting to hear back from RealTruck.com....
Old 09-03-2011, 01:48 PM
pfb's Avatar
pfb
pfb is offline
Weren't these just released? Would you mind posting a picture or two and your thoughts on the fit/finish/etc of these?
Old 09-03-2011, 04:19 PM
Fishhawk460
Yes they were just released. They still have not listed them online.
I'll try to take a couple pics tomorrow. The fit looks like factory. Nice and tight. I did lay down a layer of black RTV silicone along the lip of the wheel well where the liner makes contact. If you're not in an area where the streets are covered with salt in the winter then that would not be necessary.
Old 09-04-2011, 02:58 PM
Fishhawk460
Here's a few pics of the liners
Fishhawk - Fishhawk's Photos
Old 09-04-2011, 03:37 PM
Powerdude's Avatar
Powerdude
Powerdude is offline
That looks darned good.
Old 09-04-2011, 07:27 PM
juneau76's Avatar
juneau76
juneau76 is offline
Originally Posted by mikesxpress
Your dealer is attempting to have unwelcome sex with you.
Holy crap that's funny!!
Those look great. Thanks for posting.
Old 09-05-2011, 05:02 AM
mikesxpress's Avatar
mikesxpress
mikesxpress is offline
Couple pointers to save a little time installing these.
<O</O1. You DO NOT need to take the wheel/tire off.<O</O
2. There is a drivers side and pass side. DS marking is barely legible on the top of the insert.<O</O
3. Trim the excess out of the two semi-drilled holes in the insert prior to installing.
4. Get the front of the insert (shock mount) inside the wheel well 1st and then work the back in with a flat tip till the lip pops inside.<O></O>
5. I used clear silicone to seal inside the area between the insert and the truck well lip. That should keep road crud and salt from getting behind it?<O></O>
6. A 2nd trim plug goes in thru the back of the liner on the passenger side. *Same place where the gas vent hose was R&R'd. <O></O>
Tools:<O></O>
Razor knife<O></O>
Med flat tip screw driver<O></O>
3/8" drive ratchet/ 4" extension/10mm socket<O></O>
*Optional clear silicone. <O></O>
I also got some 18" wide black rubber faced coveyor belting and finished the enclosure job by attaching it to the back of the liner and running it back above the shackle to the inside of the bumper. Based off my other trucks and what I can see on this one, the road crud/mud slings back and builds inside the cavity along the bed and inside the bumper then rust starts.
Old 09-07-2011, 09:59 AM
ReForder's Avatar
ReForder
ReForder is offline
Those look fantastic!
Thoughts on them rattling loose and/or quality of the plastics over time?
Old 09-07-2011, 05:13 PM
mikesxpress
They are never coming out of there!!!!!!! Quality is just as good as previous factory ones on the 2000 and earlier trucks.
Old 09-07-2011, 05:20 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Those liners look great. Too bad they don't have them for the SD. I sent them an e-mail and they said they were not available. Guess I'll keep looking.
Old 09-09-2011, 07:44 PM
Fishhawk460
Not suprised. They only started overing the F150 liners in the last couple of weeks.
  #28
Old 09-13-2011, 06:26 PM
New2Fifty's Avatar
New2Fifty
New2Fifty is offline
Are they available for the 2011 F 250? Website shows Chevy/GMC?
  #29
Old 09-14-2011, 04:06 PM
mikesxpress
Liners
The pic you see above is the liners for the 2011 F150 installed. Go to the Rugged Liner website and search for your local dealer or on-line retailer. I paid $105.00 for my set.
  #30
Old 09-14-2011, 06:23 PM
New2Fifty's Avatar
New2Fifty
Thanks Mike...
Quick Reply: Wheel well liners
