88 f350 overheating
Check and make sure the water pump shaft isn't loose. (that wouldn't make it over heat, but it's a good thing to check before a long trip!)
Since you changed everything, only thing left is a fan clutch. Is it locking in? Can you hear it? You should clearly hear it when it locks in!
How do you know it's overheating?
Are you going by the crappy dash gauge?
What kind of thermostat did you use? Use FORD or International T-stats ONLY.
Received 3,114 Likes
on
For anyone wanting to know, this is what a fully functional fan clutch should sound like on one of these trucks!
When you start the engine cold and drive for a 'lil while, it will be locked, and will unlock as you drive.
It sounds like an air plane! ......or a bad front wheel bearing on a late 90's GM car
YouTube - ‪What a Fully Locked in Fan Clutch Should Sound Like‬‏
We have 2 IH dealers here, the one I always go to, have everything for our IDI's, infact, alot of stuff is in stock!
on
My fan clutch doesnt make a lick of noise at all, would that explain the overheating problem i have when driving @ 65-70 mph after 50 miles? it overheats, then if i slow down you can visibly watch the gauge go back down. It does it sometimes, but on the last 40 mile stretch from billings to missoula, from Drummond to missoula, it stops overheating....wtf lol.
on
wahlturfcare
01-31-2014 09:51 PM
